Temporarily Removing Gas Furnace In Garage? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-06-2011, 03:28 AM   #1
Temporarily removing gas furnace in garage?
In our garage we have a wooden stand built with 2x4's. It's supporting our water heater and gas furnace. There was a water leak a few years back that caused some water damage.
What I want to do is temporarily disconnect/remove the gas furnace off the stand so that I can clean up water damage or replace the stand. Is this something a professional HVAC should be doing or can I do it myself. If a professional is needed how much do you suppose it would cost?
ANGRYKOREAN is offline   Reply With Quote
Old 06-06-2011, 05:26 AM   #2
If there's no AC you can do it easy enough. Unscrew the duct from the furnace,disconnect the flue and gas and electrical. If there's AC then you might want to hire the job out since a damaged coil or kinked lineset will be costly.
Old 06-06-2011, 05:53 AM   #3
Sorry I should have been more specific.
On top of the furnace is an evaporator coil and something else on top of the coil.. don't know what that is but it's padded with insulation.
Any idea how much a professional would charge to disconnect and reconnect?
Thanks.
Old 06-06-2011, 06:33 AM   #4
DIY staff
Rewards Points: 7,174
Post a picture--There may be a way to temporarily support the unit with two pieces of 3 inch angle iron
and some blocking. That would avoid any mechanical work.--they don't weigh a lot.
Old 06-06-2011, 07:07 AM   #5
Here are the pictures.
While I have you here.. See that wooden framed box on the right side wall under the white piping? What is it?
No idea what it is..
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 08:43 AM
Garage renovation/vaulted ceiling & removing "ceiling joists" brandonlaundry Building & Construction 7 02-20-2011 11:27 AM
new (used) garage furnace coldnorth HVAC 11 12-31-2008 08:19 PM
garage furnace mrseebro HVAC 3 01-07-2008 07:25 AM
