Tempermental Ignition - Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 02-26-2012, 08:33 AM   #1
tempermental ignition - furnace
Hi,
i have a furnace that is about 16 yrs. old. Recently it will come on and blow cold air. If you turn the swich for power off momentarily, and then
turn it back on ,the burner ignites and it cycles fine.
it will go for a day or so working fine. then the same thing happens. i've replaced the batteries in thermostat, and run it on program . it works fine in either mode until it missfires
thanks,
T-bone
T-bone59 is offline   Reply With Quote
Old 02-26-2012, 08:45 AM   #2
An old Tradesmen
Rewards Points: 8,234
Next time it stops working, before turning power off. Look for a flashing ED light through the blower panel sight glass. Then look for the legend on the back of that panel.
Old 02-26-2012, 08:55 AM   #3
ED?
hvac5646 is offline   Reply With Quote
Old 02-26-2012, 09:04 AM   #4
furnace is not that new, does not have LED lights or control board
Old 02-26-2012, 09:13 AM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 396
brand and model # will help.
Old 02-26-2012, 10:11 AM   #6
it says General Heating Equipment, built in York . does this meea n its manufactured by same Co that makes York furnaces ?? Im not home so i cant get model# right now
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
Electronic ignition furnace question rcossebo HVAC 4 11-23-2008 01:02 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Electronic Ignition Furnace will not stay burning Drennen HVAC 3 12-29-2007 01:20 AM
