Temperature On Suction Line - HVAC - DIY Chatroom Home Improvement Forum
Old 02-06-2011, 01:35 PM   #1
temperature on suction line
Hello,
Two-year old Trane heat pump cannot keep more than 6 - 8 degrees difference between return and register (any of them), regardless of what the temp is outside.
Took the temp of the suction line at the compressor and it hovered around 65 - 70F. On the other unit (same kind and age and which is working fine) the temperature at the line was 92F.
Does anyone knows what condition (s) this may indicate. I do not have a gauge to measure 410, so I do not know the gas quantity.
thanks
frank otero is offline   Reply With Quote
Old 02-06-2011, 03:36 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
have a EPA licensed pro check it out. sounds like there is an issue, could be any number of things
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 02-06-2011, 05:27 PM   #3
hvaclover's Avatar
capacity in heat cycle come to mind.
Could have lost gas, bad metering device..whole bunch of stuff.
Just slow, not stupid.
hvaclover is offline   Reply With Quote
condensation on double pane windows netminder HVAC 18 01-06-2013 08:18 PM
condensation on suction line SAMMY25 HVAC 9 06-03-2012 12:59 PM
Can a roof vent identify where my main sewer line exits the house? YerDugliness Plumbing 8 01-26-2010 05:13 PM
sewer line Master Brian Plumbing 3 05-25-2009 01:53 AM
electric line and gas line couch potatoe Electrical 17 09-30-2008 11:43 PM
