Old 05-08-2012, 01:43 PM   #1
Temperature drops but thermostat reading rises
My thermostat turns on the a/c, and the temperature in the house drops, but the temperature reading on the thermostat actually rises, which means that the a/c doesn't turn off. I replaced the thermostat, thinking this would solve the problem, but it didn't. The same thing happens with the new one. I felt the wall around the thermostat and it doesn't feel warm. Any idea what's happening, or any suggestions? Thanks.
gbekurs is offline   Reply With Quote
Old 05-08-2012, 02:35 PM   #2
Well some of the pros will chime in but I have a question.
Did you relocate the thermostat from where it was originally? I would assume this hasn't always been a problem?
If so, it's possible you may have located it in a poor area. Maybe it is by a window or door and a draft is being created when the system is on, thus pulling in warmer outside air?
I cannot figure any other sceneario considering the tstat just measures the surrounding air temperature. If it's going up, as you state, then you have to be circulating warmer air past it. Does it never go down or is it just slow in going down?
Good luck
Ralph III is offline   Reply With Quote
Old 05-08-2012, 02:54 PM   #3
Thanks. I just bought the house, so I don't know whether this was a problem previously. I think the thermostat has been in the same place since construction (30 years).
Old 05-08-2012, 05:50 PM   #4
biggles's Avatar
did you put your nose/face up to the opening on the wall where the wires come out of to see if there is draft.feeling the wall won't tell anything tape over the hole 2-3 strips of tape then reinstall the subbase
Tags
a/c, hvac, inaccurate, temperature, thermostat
Need help replacing an OLD General Controls Thermostat ohman HVAC 3 06-08-2011 06:35 PM
Replacing old Honeywell thermostat with new Honeywell thermostat optimizer HVAC 13 04-20-2011 07:22 PM
how to stop condensation on windows? cake General Discussion 7 11-22-2008 01:12 AM
Thermostat reading incorrectly - cooling only CindyWOOOHOOO HVAC 5 06-27-2008 09:51 PM
Sweating windows big daddy-o General Discussion 15 01-06-2008 03:41 PM
