Temperature - HVAC - DIY Chatroom Home Improvement Forum
Old 01-11-2013, 02:57 PM   #1
Rewards Points: 326
Temperature
Hello All
Not sure where this should be posted, but i have an issue that i am looking for what might it be.
Being winter here in Toronto, Canada. we must run our HVAC unit to keep our homes warm, so my thermastat is set to 22 celcious. The temperature on the main floor reads 22, however on the second floor (where our bedrooms are), the temperature is only 20 celcious. Its 20 in every room.
Why is that? What could i do to increase the temp, without raising the temperature of the main floor?
What causes this kind of issue?
Amitabh is offline   Reply With Quote
Old 01-11-2013, 09:20 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,112
Could be any number of issues.
Heat loss via air loss or conduction losses can drive temperature differentials.
Poorly sealed or balanced ducts can also affect distribution and balance.
Much more information would be needed about the home to clearly identify the causes.
Old 01-11-2013, 09:27 PM   #3
Rewards Points: 13,300
Thermastat location, no gaps under the doors, no or poor location of return air ducts, poor insulation in the attic, no air sealing in the attic.
SOmething as simple as partly closing some of the down stairs vents may forse more air up stairs.
Old 01-12-2013, 09:20 AM   #4
Rewards Points: 326
Hello
What kind of information/factors/variables/measurements could i share with you?
My HVAC unit is a trane90, my house is 2700sq ft.
when i moved in all the external caulking was cracked and exposed. So, when i peeled back the old cracked caulking, i also noticed that there was no backer rob or window foam insulation. I was able to fix it for two windows, the other windows i just sealed over until the summer, when i will remove it.
Should i remove my moulding on the inside around the windows, and see if its insulated there?
other thoughts or ideas i could look at?
thank you in advance for the help
Amitabh
Old 01-12-2013, 09:34 AM   #5
Windows are only a fraction of the issue.
Google Air Sealing and Insulation.
Old 01-12-2013, 09:44 AM   #6
Old wooden single paned windows?
Old 01-12-2013, 09:58 AM   #7
Rewards Points: 326
i wish, my house is 8 years old and my windows are double paned.
it couldnt be the insulation (or lack of) behind the drywall right, i would assume the temperature to be much lower then no?
Old 01-12-2013, 10:29 AM   #8
Rewards Points: 226
so you wish you had old crappy windows ?
Fix'n it is offline   Reply With Quote
Old 01-14-2013, 10:00 AM   #9
Rewards Points: 326
i wish i had crappy windows, that way i know what my problem is!
im going to see if i can find any holes in my duct work in the basement and tape them up with aluminum tape. Maybe that will help. but still 2degree difference between floors. :|
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 08:42 PM
caulking old wood windows andyman Windows and Doors 10 12-31-2011 04:39 PM
Condensation amyevans Windows and Doors 6 10-21-2011 11:11 PM
Moisture on windows baum Building & Construction 56 12-22-2009 06:39 PM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 03:41 PM
