Old 10-28-2009, 10:12 AM   #1
Joe F's Avatar
Default Temp switch / aquastat?
I have a small radiant zone as part of my hydronic baseboard heating system. The radiant zone has it's own thermostat to control the zone pump, but in order to keep the boiler from short cycling, the radiant zone does not fire the boiler. I would like to install a temp switch in line with the pump power supply so that the pump will only run when the boiler water is above 90. I'm not exactly sure what product I need to do this. Any recommendations? Thanks.
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
Old 10-28-2009, 04:20 PM   #2
An old Tradesmen
L4006B aquastat. But most of them, are 100° min.
Old 10-28-2009, 04:36 PM   #3
You can try calling a local boiler supply company and ask them for a aqua stat that can do that. They should know what to do and could provide you with a Honeywell series (as beenthere has stated) or Johnson Controls controller...
Honeywell Makes controllers that range from 40-120F...so you should be able to get one.
Viper16 is offline   Reply With Quote
Old 10-29-2009, 01:38 PM   #4
Joe F's Avatar
Thanks Gents, exactly what I need.
More On This Topic
Hi my name is Seth Gordon coming at you Boca Raton, Florida on behalf of Expert Village. Today I'm going to be covering several steps in the dance hall and reggaeton music. We are going to cover some steps that are beginner and advance. If you have... Read More »
When you're trying to save money each month in energy costs, one of the first and best places to make a change is in the hot water system of your home. Homeowners can end up spending hundreds of dollars more per year than they should as a result of an... Read More »
When you need to pump water to a distant field, sometimes it's not convenient to run the pump with electricity. In such an application, a solar pump works well. Fortunately, you can do this yourself. This eHow can help you get started. Read More »
If you add a hydraulics system to your car, you're going to be dealing with relatively complex wiring tasks. Car enthusiasts with a good working knowledge of wiring and electricity can wire their own hydraulics, though inexperienced individuals should... Read More »
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 05:06 PM
4 way switch confusion Richo Electrical 10 04-09-2009 09:11 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 08:14 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 03:19 AM
Switch over temp walker45 HVAC 2 01-01-2007 11:54 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
