Old 10-08-2012, 06:04 AM   #1
temp sensor
I'm not sure were the temp sensor is on a RHEEM furnace model UGAC-080C. Once I locate it were is a good place to purchase one.
Thank Robert
Warf73 is offline   Reply With Quote
Old 10-08-2012, 06:47 AM   #2
temp sensor
How do you know it's bad and what caused it to go out? Flame roll out switches(temp sensors) trip when a flue is plugged,something wrong with the inducer or there's a hole in the heat exchanger. Limit switch fails because of not enough air flow or the furnace is grossly over fired. It's also a temp sensor.
Old 10-08-2012, 06:50 AM   #3
temp sensor
Found this on another site
"The furnace lights up, but the blower will not turn on if I have the thermostat in the auto position. The blower will turn on if I turn the thermostat to the fan position."
and his fix was
"I changed the temp sensor and everything is working like a champ."
The issue the other guy had is the same exact issue I'm having.
Old 10-08-2012, 12:43 PM   #4
temp sensor
That would be a fan limit switch. It's located in the front of the heat exchanger. New ine eill need to be the same length.
Old 10-08-2012, 12:45 PM   #5
temp sensor
Need to be the same length is supposed to be what that says
Old 10-08-2012, 12:46 PM   #6
temp sensor
Thanks sir, will one of the big box stores have one? aka lowes ,home depot, southerlands?
My temp sensor works, But the furnace not blow the heat, no heat may18 HVAC 3 01-06-2012 09:57 PM
Peerless oil furnace - keeps turning on when temp exceeds target temp eugenet1979 HVAC 0 12-22-2011 09:30 PM
ACONT800 Thermostat and Outdoor Temp Sensor tbzep HVAC 2 11-28-2010 07:31 PM
Network or usb temp sensor secutanudu HVAC 2 02-06-2010 09:07 AM
Remote Temp Sensor and zonal Room dsc522758 HVAC 1 10-25-2009 07:15 PM
