Temp Rise In Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 11-24-2014, 09:43 PM   #1
chitownken's Avatar
Rewards Points: 510
Temp rise in furnace
I have a Ducane 95G2UHV90 2 stage furnace. The temp rise ratings are 30 - 60 (low fire) and 45 - 75 (high fire). I measures them and I am at the low end in both ranges. 30 degrees on low fire and 44 degrees on high fire. Is this acceptable, or should I back the blower off a bit to get the temps up? I clocked the meter on low fire and it is dead on with what is in the manual.
Is there an advantage / disadvantage to being on the low end of the team rise?
chitownken is offline   Reply With Quote
Old 11-24-2014, 10:21 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,122
You want to be in the middle. If it is too low it can condense water in the primary heat exchanger and damage it. Should have dip switch settings on the board as it is a V drive ECM motor.
Old 11-24-2014, 10:41 PM   #3
chitownken's Avatar
Rewards Points: 510
Thanks, Yuri. It has jumpers on the board to set the fan speed. Will move to the next speed down and see what the temp rise is. Thanks a bunch.
Old 11-24-2014, 11:23 PM   #4
Hvac Pro
yuri's Avatar
Yur Welcome. Nice furnace.
Use a Merv 10 filter to keep the secondary coil etc nice and clean. Then check the temp rise.
The Following User Says Thank You to yuri For This Useful Post:
ben's plumbing (11-24-2014)
Old 11-25-2014, 12:32 AM   #5
Rewards Points: 6,744
The better 2-stage ecm furnaces (carrier/lennox/york/trane/goodman etc) come setup to maintain the same temp rise on high and low.
30 on low fire is too low and you should reduce the speed.
user_12345a is online now   Reply With Quote
Old 11-25-2014, 05:20 AM   #6
An old Tradesmen
Rewards Points: 6,112
Doesn't sound like your blower is running in its first sage heat speed. Do you have your fan set to run 24/7?
Old 11-25-2014, 07:26 PM   #7
chitownken's Avatar
Rewards Points: 510
Beenthere,
Have a Honeywell stat set on circulate so fan does not run 24/7. It does ramp up the fan when it goes to high fire, I just think the installer set the jumpers too high. I set it back to what the manual shows as the factory default and now I get 43 degrees rise on low fire. Did not feel like jacking the stat to get it to go into high fire. Not cold enough to get it to go into high fire except in the morning when it comes back from night time setback. And that's pre-coffee so any measurements taken then would be suspect.
Yuri,
Have the 3M 1900 pleated filter. Not sure what the Merv rating is on those. Change monthly.
User_12345a,
Lennox makes Ducane, but board might be different. Runs on low fire most of the time unless Yuri sends that Canadian air our way.
Thanks, guys.
Old 11-25-2014, 07:54 PM   #8
Hvac Pro
yuri's Avatar
2-3 years ago they made Ducane/AirFlo/Armstrong furnaces identical to the Lennox as they bought Allied Air. Except for the high end mod SLP. Before that Ducane had it's own board etc.
There is some way to cross ref those 3M to Merv but you have to dig on the net for 1/2 an hour to find that site. Google works different than BING so try both.
Old 11-25-2014, 08:32 PM   #9
Low heat speed is nearly the same has high heat Ducane/AirFlo/Armstrong models.
I think it's to differentiate products and charge a premium for something with a lennox sticker on it.
Carrier puts crappy firmware on the ICP furnaces too; the variable speed models don't maintain airflow as the static pressure increases.
Old 11-25-2014, 08:55 PM   #10
chitownken's Avatar
Rewards Points: 510
Turns out they are Merv 12 filters
http://www.iallergy.com/filtrete-air...comparison.php
Furnace was 2 years old this September. Replaced an oversized York 80% unit. Really like the 2 stage heat and 2 stage cool. Saving a bunch on gas and electric and the house is more comfortable.
The Following User Says Thank You to chitownken For This Useful Post:
ben's plumbing (11-25-2014)
Old 11-25-2014, 09:09 PM   #11
Rewards Points: 242
Where are you measuring the temperature rise at. Measure the temp as soon as the heated air enters the plenum of the furnace. Do not take your heated air measurement at the register to calculate temp rise
collegetry is offline   Reply With Quote
The Following User Says Thank You to collegetry For This Useful Post:
Chris130 (11-25-2014)
Old 11-25-2014, 09:46 PM   #12
chitownken's Avatar
Rewards Points: 510
Measuring return temp about 2 inch before the filter where all the returns come together. Measuring supply temp about 1 1/2 inches above the A-coil in the supply plenum before any of the duct runs branch off. Temp probes go in about 4 inches or so and do not contact anything. Let it run for a few minutes to stabilize the temps.
Old 11-25-2014, 11:18 PM   #13
Rewards Points: 2,512
I did almost the exact same as you last year to check mine. I used a "dual probe thermometer"
Note: in the first picture I have the leads incorrectly labeled as the probes.
Temp rise in furnace-100_7617.jpg   Temp rise in furnace-100_7618.jpg   Temp rise in furnace-100_7623.jpg
hammerlane is offline   Reply With Quote
Old 11-26-2014, 05:27 AM   #14
An old Tradesmen
Best to have your supply probe in the supply trunk, about 1 foot in. That way the sensor is not effected by radiant heat. And the air has a chance to completely mix.
Natural Gas Cost For Furnace 1 Hour Run Time hammerlane HVAC 25 01-14-2015 03:13 PM
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Quote for new furnace. Reasonable? dengle HVAC 16 03-04-2012 08:01 AM
Furnace inducer motor always running, even temp reached Ballastar HVAC 2 10-08-2010 04:54 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
