Temp Lockout For Heatpump - HVAC - DIY Chatroom Home Improvement Forum
Old 01-03-2015, 06:23 AM   #1
Rewards Points: 4
Temp lockout for heatpump
I have installed my own Hybrid HVAC system. I have a 4.5 ton heatpump with a propane furnace backup. My system works extremely well except when my thermostat calls for backup heat (propane) the outside unit continues to run when the propane is burning. I feel like this is a waste of electricity so what I need is someone to steer me in the right direction of where to purchase or how to install an external stat or temp relay that will lockout my outside unit when the outside temp dips below 30 degrees or so. Thanks
Raven2014 is offline   Reply With Quote
Old 01-03-2015, 07:08 AM   #2
An old Tradesmen
Rewards Points: 5,598
Unless your heat pump is a geo(which wouldn't have an outdoor unit). They don't come in a 4.5 ton size.
What thermostat do you have? Post brand and full model number.
Old 01-03-2015, 07:33 AM   #3
Rewards Points: 4
It's a BGE peak rewards thermostat from the utility. But it is a Honeywell T2060F
Old 01-03-2015, 08:36 AM   #4
An old Tradesmen
Looks like its installer set up is crippled from the factory.
A Bill Porter dual fuel control will work.
http://www.theheatpumpmadeeasy.com/
Old 01-03-2015, 10:43 AM   #5
Rewards Points: 1,996
That's a custom thermostat designed with specs supplied by your utility company and therefore its advanced settings are locked out.
You need to buy a new thermostat so you have access to the advanced settings (compressor lock out temp for one)
Bob Sanders is offline   Reply With Quote
Old 01-03-2015, 11:13 AM   #6
An old Tradesmen
Bill Porter board is cheaper then a new stat, and works well.
Old 01-03-2015, 12:20 PM   #7
Rewards Points: 1,716
I think you may be surprised at how much your heat pump will help at 30 degrees if it's working properly. If you go through with this change you might want to experiment with a setting around the 15-20 degree range.
zappa is online now   Reply With Quote
set lockout temp for HP w/carrier tstatcctrh01-B lagotz HVAC 0 01-31-2013 08:02 PM
hi temp boiler cutoff jmon HVAC 20 12-05-2012 09:01 PM
Peerless oil furnace - keeps turning on when temp exceeds target temp eugenet1979 HVAC 0 12-22-2011 09:30 PM
Infinty 19 Hybrid System-Furnace lockout aonorat HVAC 4 11-03-2010 12:14 PM
AC Temp drop over plenum run length BlueBSH HVAC 23 06-22-2010 09:10 AM
