Temp Differences In Rooms - HVAC - DIY Chatroom Home Improvement Forum
Old 01-08-2013, 10:46 AM   #1
Rewards Points: 129
Temp differences in rooms
New home in NE Pa. HP with propane back-up. Measured the outputs from my vents using an infrared gun while running gas. Some vents have 110 deg. readings while others are 95 deg. Also, two vents in room above garage. Vent closest to the main structure as well as furnace shows 108 while vent furthest out reads 94.
Are thes variances acceptable? Home has 6 in walls along with 6 in insulation.
Are these variances acceptable?
jeepgrady is online now   Reply With Quote
Old 01-08-2013, 11:03 AM   #2
I'm Your Huckleberry
Rewards Points: 2,270
I'd check for any possible leaks in the ductwork. Usually I'll see a single degree , possibly two in difference, culprit being longer ducts meaning the further the air has to travel the more it will cool down but 10 degrees difference is highly unusual.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 01-08-2013, 06:34 PM   #3
how
Rewards Points: 1,104
I'd take those temps again with the heat off and the summer fan on. If the temp differences are the same, then you have some serious building envelope/insulation flaws.
how is online now   Reply With Quote
Old 01-08-2013, 06:57 PM   #4
Roofmaster
Rewards Points: 2,172
Use a real thermometer. IR Guns can be way off. especially if your talking about those cheap things. My first IR camera cost 33K whats that tell you?
What size to make non-master rooms KarlJay Remodeling 37 11-07-2012 09:47 AM
Should I put the same hardwood in all the rooms? alessandrot Flooring 13 06-13-2012 08:23 PM
boiler temp overshoot johnnyzero HVAC 0 11-08-2011 10:52 AM
New Kenmore Range 790.92604 wide fluctuation in oven temp tkolarik Appliances 5 09-10-2011 09:17 AM
Best High Temp Paint for wood stove?? Sellncars Painting 9 01-21-2009 07:21 PM
