Temp. Control Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 02-11-2010, 08:04 PM   #1
temp. control problem
furnace seems to drop in temp. when I reset temp. rises back to setting
I have a concord furnace, it is about 6 years old
jim360 is offline   Reply With Quote
Old 02-13-2010, 07:47 AM   #2
An old Tradesmen
Rewards Points: 6,148
Does that mean your stat calls for heat but the furnace doesn't come on. Until you turn the stat down and then back up?
Old 02-13-2010, 09:42 AM   #3
yes, but it takes some time for the pilot to light
Old 02-13-2010, 10:19 AM   #4
Licensed Master Plumber
The anticipator in the thermostat may be set to the wrong milliamp setting. Is it pilot ignition or Hot surface?
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 02-13-2010, 01:17 PM   #5
I believe it is hot surface
Old 02-13-2010, 02:15 PM   #6
do you think it could be the hot surface ignitor, if so which one do you recommend. the carbide or nitride
Old 02-13-2010, 03:15 PM   #7
An old Tradesmen
Its probably not the HSI.
What brand and model is the thermostat, and furnace.
Old 02-14-2010, 07:56 PM   #8
temp.
the stat. is a honywell and the furnace is a concord(2004)90% eff.
getting fault that reads: lock-out due to no ignition-7 flashes
Old 02-14-2010, 08:06 PM   #9
An old Tradesmen
Honeywell makes more then 500 different thermostats. So what model number is yours.
Could be a pressure switch, or flame sensor.
Now if its a model, for get it. Your concord probably isn't that model.
Old 02-14-2010, 08:24 PM   #10
temp.
honeywell-CT3451
concord-8404G08507
Old 02-14-2010, 08:32 PM   #11
An old Tradesmen
Check your flue/chimney for restrictions.
check hose to pressure switch for moisture in it.
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 05:28 PM
Gas water heater poor temperature control nanoplane Plumbing 3 01-24-2010 09:29 AM
HELP!! NEW Control Board & Same Problem!! Steve72 HVAC 3 02-11-2009 03:48 PM
Blower Problem tk027627 HVAC 1 03-02-2008 11:59 AM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
