Old 09-12-2012, 11:09 AM   #1
Coconut Pete's paella!
CoconutPete's Avatar
Tell me about my water heater:
My other thread inspired me to make this one. Wanted to get some pics in. I'm planning on having this replaced in the next couple of weeks for a couple of reasons:
It's 43 years old
There's a good amount of rust where the pressure valve exits the body
There's a good amount of rust where the hot water pipe exits the body
I've never done any maintenance on it (3 years)
I have no idea what the previous owner did
The company who made it is out of business.
It says "Copper Core" on it - does that mean I should not let the company installing the new one scrap this one?
Pics to follow.
CoconutPete is online now   Reply With Quote
Old 09-12-2012, 11:11 AM   #2
Pictures:
Tell me about my water heater:-image-1365787886.jpg   Tell me about my water heater:-image-704414922.jpg
Old 09-12-2012, 11:13 AM   #3
More pics.
Tell me about my water heater:-image-3020464248.jpg   Tell me about my water heater:-image-778227482.jpg
Old 09-12-2012, 04:22 PM   #4
An old Tradesmen
Not familiar with that brand.
Old 09-12-2012, 08:17 PM   #5
Super Moderator
New one on me,too.
Scrap copper is about $3.00 a pound----
Old 09-12-2012, 08:39 PM   #6
Missouri Bound's Avatar
If it works well, clean up the rusty fittings and inspect the tank. By design the water will last for years. Make your next one a Marathon if rust is an issue.
Do you want it your way or the right way?
Old 09-13-2012, 11:29 AM   #7
I'll grab a pic of the rust later. It's not the fitting - it's the housing itself.
The Following User Says Thank You to CoconutPete For This Useful Post:
Missouri Bound (09-13-2012)
Old 09-14-2012, 08:08 AM   #8
Pics of the back.
Tell me about my water heater:-image-1437756972.jpg   Tell me about my water heater:-image-2822067769.jpg
Old 09-14-2012, 09:43 AM   #9
Looks bad. You can pick away at it and see if it's just surface rust....which it probably is. I think it's more cosmetic right now than mechanical. However....and it's a big however; if you decide to replace the tank it will no doubt be much more efficient than that old one. New burner design, electronic ignition and better temperature controls have made them much more efficient.....but it's your money.
Old 09-14-2012, 03:43 PM   #10
An old Tradesmen
Best to be preemptive and change it out before it rust through the whole way. New water heater will save you a few bucks if you get a pilotless one, and the new ones are a bit better insulated. not eally more efficiency combustion wise. unless you pay and extra couple hundred.
Old 09-14-2012, 11:30 PM   #11
That's the part I'm confused about. Does "copper core" mean it won't rust through all the way?
Old 09-14-2012, 11:35 PM   #12
I've never seen a copper tanked water heater, but that doesn't mean they didn't exist.....only one way to find out.....saw time.
ryan50hrl is offline   Reply With Quote
Old 09-14-2012, 11:38 PM   #13
An old Tradesmen
Could be copper tinned inside. Which means it could pit through.
Old 09-15-2012, 12:00 AM   #14
Pushing it. Go away and you come home to a flood.
bobelectric is offline   Reply With Quote
Old 09-15-2012, 08:56 PM   #15
newtech's Avatar
http://fultonhistory.com/newspaper%2...20-%200052.pdf
http://rrlcnewspapers.org/Fairport%2...20-%201252.pdf
newtech is offline   Reply With Quote
The Following User Says Thank You to newtech For This Useful Post:
bob22 (09-16-2012)
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 01:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
water heater drip kdange1 Plumbing 5 05-04-2010 04:24 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
