Tee In Branch Good Or Bad? - HVAC - DIY Chatroom Home Improvement Forum
Old 09-14-2012, 01:39 PM   #1
Rewards Points: 77
Tee in branch good or bad?
Trying to finish basemnet. Previously there were two round branches coming out of furnace/trunk they were running side by side. One branch was 8" and one was 7". Would like to make soffet smaller. Could I instead put it in a tee in 8" and tap a 7" in the end? Just wondering if this is going to mess up air flow. Please see pictures/attachments. The bottom one is where I want to tee into. The top picutre has a sheet stuffed into it. That's where the 7" used to run next to the 8"''. I have it completely removed at the moment.
Thank you.
Tee in branch good or bad?-imag0003.jpg   Tee in branch good or bad?-imag0014.jpg
nateo is offline   Reply With Quote
Old 09-14-2012, 04:04 PM   #2
An old Tradesmen
Rewards Points: 6,474
You would need a 10" pipe to feed a 8 and a 7" run. Using a 8" to feed a 8 and a 7" won't give good air flow to either run.
NJ Lumber Yards - good suppliers for decking? Quicksmoke Building & Construction 5 03-23-2012 02:50 PM
What is a good efficient heating system for cold climates? reveriereptile HVAC 7 02-08-2012 09:26 PM
Substituting a Murray for Siemens branch breaker mfreeland Electrical 14 12-04-2010 10:04 AM
Where can I find good contractor and building material suppliers? denniis Off Topic 5 03-10-2009 10:27 AM
