Tech Says Only Solution Ad A Heat Strip For $150.00 - HVAC - DIY Chatroom Home Improvement Forum
Old 01-02-2011, 11:02 AM   #1
Tech says only solution ad a heat strip for $150.00
Model number WCH048F100AA 13 SEER 4 TON HEAT PUMP---- AMERICAN STANDARD
Will a heat strip stop the unit from running in defrost all night long? Last night had the temp set for 72 and it ran at 65 degrees all night long. Now they are saying I don't have a warranty on this unit!
I have the current situation going on below:
I live in Az. and when the temperature dips below 40 degrees the unit freezes up and it runs constantly in defrost mode- iced up. I set my thermostat at 70 and the unit will run and run at 65 all night long. In the morning the unit is covered in ice.
The unit is barely 1 year old and it is an American Standard heat pump 13 seer four ton package. The Technician has been out since day one and can't figure this out.
Several techs have been out and they can't figure this out. They can't find anything wrong with the unit.
desertsage is offline   Reply With Quote
Old 01-02-2011, 12:24 PM   #2
I don't think you understand what defrost mode is. Defrost switches the heat pump into cooling mode so some of the house warmth is transfered to the outside coils to defrost them. Without back up heat the air coming out of the registers will be 40 degrees.In defrost the outdoor fan will shut off with the compresor running.
Heatpump vs Natural Gas - Energy Cost Spreadsheet zootjeff HVAC 11 06-22-2015 03:59 AM
The Hows and Whys of Furring Strips. Part-1 Willie T How To Guides 12 03-01-2013 02:58 PM
Service tech won't repair furnace with cracked heat exchanger. GloBigRed HVAC 16 11-18-2010 02:27 AM
Radiant floor heat under 3x8 feet wide strip of tile - how to build up rest of floor? lazzlazz Flooring 2 03-31-2010 05:52 AM
Ruud heat strip furnace blower TKELLY HVAC 4 03-08-2010 02:09 PM
