Tapping Into Cold Air Return - HVAC - DIY Chatroom Home Improvement Forum
Old 02-23-2011, 07:15 PM   #1
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
tapping into cold air return
I have a hall closet that i use as a home theater cabinet. my reciever, DVD, and directv reciever are all in there and it can get a little warm when they've all been in there for a while, so I usually have to leave the door open. i have been thinking of a way to vent the closet with the door closed, and have looked at many different options. tonight i thought of a super cheap solution that I wanted to throw out there
My cold air return runs directly behind the closet, so I'm wondering if the cheapest and easiest solution is to just cut a 3" hole through the drywall and into the return, and screw a $15 USB powered fan over the hole so whenever the reciever is turned on it will push the warm air from the closet into the return.( I assume the sheetmetal is right behind the drywall). The closet and hallway have hardwood floors, so i figure there is plenty of space between the bottom of the door and the floor to allow cool air to come in
Does this make sense? Any potential issues with going this route?
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 02-23-2011, 09:54 PM   #2
An old Tradesmen
Rewards Points: 6,500
Code prohibits a return being in a closet. So it would be a code violation.
Old 02-23-2011, 11:14 PM   #3
Why not put a grate/louver in the door?
VIPlumber is offline   Reply With Quote
Old 02-24-2011, 01:31 AM   #4
HVAC Supermodel
unicursalhex's Avatar
Rewards Points: 150
If there's attic space above the closet why not put a bathroom fan up in that b!tch? This is DIY after all. If you wanted to get real crafty you could make it operate by closet temperature, yeeeaaaahhh boyyeeeee!
unicursalhex is offline   Reply With Quote
Old 02-24-2011, 08:24 AM   #5
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
my doors look like this
and is located in the main entrance hallway, so i thing a grate would look odd, and more importantly my wife would hate it. If it was in the basement or in a bedroom I would replace the entire door with one of those louvered doors like you see in laundry rooms
It's on the first floor, so no dice. I will probably stick to my original plan which was to put a vent in the side wall, I just thought going into the return would be super easy, and not require me to have to put grates up anywhere or have to come up with some ducting to fill the small gap the will be between the drywall
Just my luck. Would have been the perfect solution, cheap, easy and effective
Cold Air Return issue ra1185DIY HVAC 1 12-05-2010 04:21 PM
Need advice on cold air return mrlouie HVAC 4 10-09-2010 05:33 AM
Cold Air Return next to supply duct thebigbbm HVAC 6 09-21-2010 06:51 PM
Cold air return questions ekulrenlig HVAC 19 10-09-2009 02:44 PM
move cold air return or add extra hot air CamL HVAC 2 03-26-2008 01:43 AM
