Tappan Not Igniting - HVAC - DIY Chatroom Home Improvement Forum
Old 10-23-2008, 11:08 AM   #1
Tappan not igniting
Tappan heat pump model: C3BA-030C-B
I cannot find much info for it online, tried to find a manual to troubleshoot. I reset the ignition module and the exhaust blower turned on for a few minutes then goes off. While it is on a here clicks every several seconds. I do not see any flame in the window and the main blower never turns on. The main blower works when I select manual on the thermostat. Fuse is good, circuit breaker is on, gas valve is open. What do I need to check?
jholder73 is offline   Reply With Quote
Old 10-23-2008, 12:59 PM   #2
You are describing a furnace not a heat pump.
Wjat is the brand and model of the furnace?
hvaclover is offline   Reply With Quote
Malfunctioning Tappan Furnace atlfiveo HVAC 3 01-27-2010 12:27 AM
More powerful blower for a Tappan? atlfiveo HVAC 4 06-08-2008 12:05 PM
furnace not igniting jjoossee25 HVAC 3 12-04-2006 05:01 PM
