Tankless Water Heater - HVAC - DIY Chatroom Home Improvement Forum
Old 09-27-2010, 08:12 PM   #1
tankless water heater
our oil company tells us we can't shut off the furnace as we have a tankless water heater attached to the furnace. We are away most of the summer so are paying for the water to heat while no one is using it. Why can't we shut down the furnace while away?
Jane Oppen is offline   Reply With Quote
Old 09-27-2010, 08:16 PM   #2
HVAC / Plumbing
The only time you pay to heat water with a tankless is when you turn on the hot water.
kenmac is offline   Reply With Quote
Old 10-05-2010, 03:56 PM   #3
Rewards Points: 107
I also have an old hot water boiler that has a domestic hot water coil that makes continuous hot water. You can turn off the boiler and save oil, but there will be no hot water unless it is on. I turn mine off and on all the time because its a summer house and when its gets real hot a warm/cool shower is fine. Sometimes we turn it on for showers,dishwasher,washing mach. then turn it off in the summer.
jerzeedivr is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 03:56 PM
Tankless Water Heater Problem Thalweg Plumbing 4 12-10-2009 01:18 PM
Tankless water heater proper pipe size? gante Plumbing 5 04-06-2009 03:28 PM
Tankless water heater - NEED HELP! LakersFreak Plumbing 39 11-16-2008 09:49 AM
