Old 08-02-2012, 08:09 AM   #1
I'm Your Huckleberry
Take a guess, any guess!
Thanks.
Doc Holliday is offline   Reply With Quote
Old 08-02-2012, 09:17 AM   #2
R22?
How long was the system running before taking these readings?
scottmcd9999 is offline   Reply With Quote
Old 08-02-2012, 10:11 AM   #3
Not an HVAC Tech but Im going to take a stab at ....5 minutes?
techpappy is offline   Reply With Quote
Old 08-02-2012, 10:31 AM   #4
What does it mean?
sarahWW is offline   Reply With Quote
Old 08-02-2012, 10:47 AM   #5
See my guesses below
ea0680 is offline   Reply With Quote
Old 08-02-2012, 11:03 AM   #6
last try below
Old 08-02-2012, 11:07 AM   #7
my last guess - I think its overcharged - is that 85 psi low and 400 psi high ? if r22, then I think that means freon overcharge.
Old 08-02-2012, 11:39 AM   #8
If it's R22, and it's stabilized, then I'd think either:
1) If TXV, then perhaps dirty condenser, in which case AFTER cleaning the unit would likely be undercharged
2) If cap/orifice, then restriction somewhere on the liquid line or metering device, and overcharged a bit.
But we'd really need to know more about the system ...
Old 08-02-2012, 03:15 PM   #9
An old Tradesmen
Plugged condense coil, and low on charge.
Old 08-02-2012, 03:23 PM   #10
To a complete novice, how would you describe those readings? Blue is low side, Red is high....and that's as much as I know.
I mean, is that a high reading on the low side? Because my system is doing that, or was, when the last tech came and said my system was overcharged/overcharging and took out some R410
Old 08-02-2012, 03:26 PM   #11
An old Tradesmen
The low side reading would be low for R410A.
Old 08-02-2012, 05:20 PM   #12
I didn't check superheat or even for a target, just cleaned it, made sure it wasn't going to trip on high pressure again (original complaint, no cool/condenser found condenser not running on call for cool) and that the pressures resembled a normal charge, changed the double pole 45 amp breaker which fried on me when I first turned it back on or tried to turn back on anyways and that was it.
All four sides as I found it.
After.
No refrigerant added or removed, just a cleaning.
Thanks.
Old 08-02-2012, 05:36 PM   #13
An old Tradesmen
Those Rheems take abuse. Unfortunately, their well made cabinet hides the dirt/blanket, so a lot of people don't realize how dirty the coil is.
Surprised it wasn't low on charge also.
Old 08-02-2012, 06:20 PM   #14
My guess is PURPLE.
"The problem with quotes on the Internet is that it is often difficult to verify their authenticity." - Abraham Lincoln
The economy is so bad, Exxon-Mobil laid-off 25 congressmen --- Maxine
gma2rjc is online now   Reply With Quote
Old 08-02-2012, 06:28 PM   #15
the Musigician
DangerMouse's Avatar
Originally Posted by gma2rjc View Post
My guess is PURPLE.
He did say ANY guess!
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Gable Ornaments? I guess this is what you call them.... cocean Building & Construction 1 12-24-2009 03:23 PM
Best guess on prices for these projects? RyanD General Discussion 4 05-26-2009 07:47 PM
Need help with refinishing oak flooring...hit a snag MrPlow Flooring 8 05-14-2009 08:09 PM
Basement Addition showtime14 Building & Construction 9 03-10-2009 07:08 PM
Dead electric forklift emergency kit powerless Electrical 12 11-20-2008 06:40 AM
