-   -   Take a guess, any guess! (http://www.diychatroom.com/f17/take-guess-any-guess-152316/)
Doc Holliday 08-02-2012 08:09 AM
http://i87.photobucket.com/albums/k1...801_133932.jpg
scottmcd9999 08-02-2012 09:17 AM
R22?
How long was the system running before taking these readings?
techpappy 08-02-2012 10:11 AM
Not an HVAC Tech but Im going to take a stab at ....5 minutes?
sarahWW 08-02-2012 10:31 AM
What does it mean?
ea0680 08-02-2012 10:47 AM
See my guesses below
ea0680 08-02-2012 11:03 AM
last try below
ea0680 08-02-2012 11:07 AM
my last guess - I think its overcharged - is that 85 psi low and 400 psi high ? if r22, then I think that means freon overcharge.
scottmcd9999 08-02-2012 11:39 AM
If it's R22, and it's stabilized, then I'd think either:
1) If TXV, then perhaps dirty condenser, in which case AFTER cleaning the unit would likely be undercharged
2) If cap/orifice, then restriction somewhere on the liquid line or metering device, and overcharged a bit.
But we'd really need to know more about the system ...
beenthere 08-02-2012 03:15 PM
Plugged condense coil, and low on charge.
sarahWW 08-02-2012 03:23 PM
To a complete novice, how would you describe those readings? Blue is low side, Red is high....and that's as much as I know.
I mean, is that a high reading on the low side? Because my system is doing that, or was, when the last tech came and said my system was overcharged/overcharging and took out some R410
beenthere 08-02-2012 03:26 PM
The low side reading would be low for R410A.
Doc Holliday 08-02-2012 05:20 PM
I didn't check superheat or even for a target, just cleaned it, made sure it wasn't going to trip on high pressure again (original complaint, no cool/condenser found condenser not running on call for cool) and that the pressures resembled a normal charge, changed the double pole 45 amp breaker which fried on me when I first turned it back on or tried to turn back on anyways and that was it.
All four sides as I found it.
http://i87.photobucket.com/albums/k1...801_135624.jpg
http://i87.photobucket.com/albums/k1...801_135553.jpg
http://i87.photobucket.com/albums/k1...801_135617.jpg
http://i87.photobucket.com/albums/k1...801_135602.jpg
After.
http://i87.photobucket.com/albums/k1...801_142114.jpg
http://i87.photobucket.com/albums/k1...801_142133.jpg
http://i87.photobucket.com/albums/k1...801_142123.jpg
http://i87.photobucket.com/albums/k1...801_142146.jpg
http://i87.photobucket.com/albums/k1...801_142159.jpg
No refrigerant added or removed, just a cleaning.
http://i87.photobucket.com/albums/k1...801_153656.jpg
beenthere 08-02-2012 05:36 PM
Those Rheems take abuse. Unfortunately, their well made cabinet hides the dirt/blanket, so a lot of people don't realize how dirty the coil is.
Surprised it wasn't low on charge also.
gma2rjc 08-02-2012 06:20 PM
My guess is PURPLE.
DangerMouse 08-02-2012 06:28 PM
Originally Posted by gma2rjc (Post 980031)
My guess is PURPLE.
:laughing::laughing::laughing::laughing:
He did say ANY guess! :laughing:
DM
