T-Stat Wiring - Lux TX9100e Replaces Honeywell T8411R For Carrier Heat Pump/Cooling - HVAC - DIY Chatroom Home Improvement Forum
Old 08-19-2010, 01:09 PM   #1
T-Stat Wiring - Lux TX9100e replaces Honeywell T8411R for Carrier Heat Pump/Cooling
I’m trying to replace my girlfriend’s old thermostat with a new programmable thermostat. I did this last night, but I couldn’t get the AC to come on… I’m hoping someone will see my error.
Many thanks,
Specs:
Carrier: Heat Pump with Cooling
Model # FA4BNF018
Product FA4BNF018 010 AAAA
Heat Pack MKFCEH0901N10
Old t-stat
Honeywell T84 11R 1002
http://customer.honeywell.com/techlit/pdf/69-0000s/69-1037.pdf
(This was wired with 8-wire as listed below.)
G = green
C = charcoal
R = red
W1 (jumper to Y) (no wire)
Y = (jumper to W1) yellow
W2 (2 wires) = white; light blue
E = black
B (No wire)
O - orange
New Tstat
Lux TX9100e
http://www.luxproducts.com/thermostats/tx9100e.htm
A (No wire)
RH jumper to RC
W2 (former w2 wires) = white; light blue; Black
RC = red
G = green
Y (Jumper W1) = Y
W1 (jumper to Y) (No wire)
O - O wire
B (No wire)
C = charcoal
Today I will also check the 3amp fuse in the blower.
Any suggestions would be great.
Josh
99Problems is offline   Reply With Quote
Old 08-19-2010, 01:44 PM   #2
Get your voltmeter and measure the following when the thermostat is calling for AC:
Y to C
R to C
C to G
Personally, I'd never substitute Lux for Honeywell.
hennyh is offline   Reply With Quote
Tags
carrier , heat pump thermostat , honeywell , lux , thermostat
Wiring a Honeywell ProVision TH8321U1006, upgrade from Weathertron Tstat drandersoninc HVAC 6 10-04-2009 03:20 PM
Honeywell stat wiring w/ Trane furnace JaePee HVAC 7 01-18-2009 06:50 AM
Wiring help - Honeywell Thermostat w/ Carrier Heat Pump Tom Williams HVAC 7 09-14-2008 07:40 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 11:49 AM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 09:10 PM
