Old 11-18-2008, 09:12 AM   #1
T-Stat trouble
Hi Everyone,
We have a heat pump/air handler system in our condo. Our probelm is when we set the T-Stat at 68 the fan is not going off when it reaches temp. It will stay on forever (we tested it). The Heat pump will shut down, but the fan remains on.
Now the wierd part. If we manually reset the temp on the T-Stat to 65, the fan will go off as long as the temp is above 65.
Is the T-Stats temp sensor going? I think the fan relay is working and the heat pump and fan seem to work as well.
Should I replace the T-Stat?
Rickl is offline   Reply With Quote
Old 11-18-2008, 10:12 AM   #2
hvaclover's Avatar
T-Stat trouble
What kind of stat is it? Do you have a programmable "Fan ON" cycle in your existing stat.? Did you make sure your fan-auto switch is in the auto position.?
Just slow, not stupid.
hvaclover is offline   Reply With Quote
Old 11-18-2008, 12:48 PM   #3
T-Stat trouble
Hi,
It is a RiteTemp 8010. It is not programable and the fan is on Auto.
Old 11-18-2008, 01:46 PM   #4
T-Stat trouble
Carefully pull the cover off and see if you have 24VAC across the G and C terminals when this happens. If so, it might indicate the tstat is bad. Then see if your volts go to 0 when you reset the temp to 65.
Let us know what you find.
dac122 is offline   Reply With Quote
Old 11-18-2008, 03:00 PM   #5
hvaclover's Avatar
T-Stat trouble
Hey dec, you ever consider maybe the site should offer loaner meters? LOL
Old 11-18-2008, 04:41 PM   #6
T-Stat trouble
check what terminals the wires are going to at the tstat make sure y is going to the Y terminal and not W or E or aux
kennzz05 is offline   Reply With Quote
Old 11-18-2008, 04:53 PM   #7
T-Stat trouble
Old 11-18-2008, 04:57 PM   #8
T-Stat trouble
Interesting thought...
Rickl, did it ever work correctly, or is this something new?
Wallpaper trouble Confused1 Interior Decorating 1 11-13-2008 02:07 PM
P0420 trouble code Bad gas milage Help!!! lemoncoke Automotive Repairs 3 10-05-2008 09:50 AM
ritetemp programmable stat miked18 HVAC 9 12-17-2007 07:20 PM
gas heater trouble toughy HVAC 2 11-04-2006 02:55 PM
