T-bar Bridges For Suspended Ceiling Ductwork - HVAC - DIY Chatroom Home Improvement Forum
Old 08-02-2012, 09:44 AM   #1
t-bar bridges for suspended ceiling ductwork
The suspended ceiling is 2 x 2 standard t-bar grid with thin vinyl tiles and 6" ductwork mounting between the joists above. Would like to install round diffusers but they cannot be attached to the tiles for support. The diffusers will need to be attached to t-bar bridges similar to those found on halo recessed lights.
I found Speedi Boot products at Home Depot which could have met the need but they only make rectangular and square boots for suspended ceilings. Thought about using a Quam SSB-9 t-bar bridge intended for audio speakers. Their SSB-9 could probably be rigged to attach to the starter collar and diffuser. However, I thought I'd ask here first to see if there is another solution.
Thanks in advance.
josephmartins is offline   Reply With Quote
Old 08-02-2012, 10:44 AM   #2
HVAC Contractor
Rewards Points: 336
Why not install diffusers intended for use with suspended ceilings:
http://compare.ebay.com/like/3604004...Types&var=sbar
Just an example - there are many other types to be found.
I've not seen a method to suspend round ceiling diffusers in suspended ceilings. Every time I see one of those, they're supported by the tile, and the tile ends up warping fairly quickly. You could use rectangular boots made for overhead installation. They come with "rails", which allow you to span the 24" space.
scottmcd9999 is offline   Reply With Quote
The Following User Says Thank You to scottmcd9999 For This Useful Post:
josephmartins (08-02-2012)
Old 08-02-2012, 11:03 AM   #3
Hi Scott,
Thanks for taking the time to reply. We appreciate it.
We thought about the 24 x 24 diffusers since they're a drop-in. But they're definitely more for industrial/commercial applications. A couple things turned use off to the idea. Their size and their appearance which, in my opinion at least, would definitely not go well with the style of ceiling since unless we can find one that is similarly recessed (see the photo). I suppose a VAV (bottom photo) might work but it's still a huge 24 x 24 and significantly more expensive than all the other options.
We thought we might rig something similar to the rectangular boot using the Quam speaker bridge to keep the weight off the tile. Not the original intended use for that product but it seems like it might work. Then we could use a 6-8" round or square diffuser cover.
Sounds like there really isn't any other way to suspend round duct and keep the weight off the tile.
t-bar bridges for suspended ceiling ductwork-westminster-white-ceiling-tiles.jpg   t-bar bridges for suspended ceiling ductwork-ssb9.jpg
Old 08-02-2012, 03:05 PM   #4
HVAC Tech/Owner
Rewards Points: 604
The weight isn't that much....
We just use a backer plate and fasten it directly to the tile. Last job we used thin plywood and sandwiched the tile in between the plywood and ceiling register.
Technow is offline   Reply With Quote
Plaster ceiling with peeling paint annaem Painting 14 01-19-2012 12:10 PM
Garage ceiling joists and beam question Truth Building & Construction 8 01-05-2012 07:52 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Need Ceiling Idea for Ductwork that cuts Across Middle of Room skylake Building & Construction 8 10-19-2009 06:15 AM
