System pricing
Hello. I have a pretty large home (about 3500 sq. ft.) with two A/C units. The one that cools the downstairs needs replacing. I live in super-hot Dallas and we have lots of glass, plus kids who leave the doors open all the time, so I am going with a 5 ton unit, gas furnace. Problem is, the pricing is all over the place, some with high pressure sales tactics. Can someone tell me objectively what is a fair price to pay for a high (15-18) SEER unit, installed? (Ductwork extra, I understand). I would choose a quality product like Goodman, Trane or Lennox.
Thanks, No2Son |
You asked about an objective price. That's dependant on brand and all the bells and whistles you want. If it was me I'd purchase a Lennox G61MPV and a 15 seer ac. G61 because it is a 2 stage gas valve meaning it will fire on low fire and after a period of time if needed it will kick into high fire to finish. It also has a variable spped motor which is controlled by dc voltage. Very nice and and not as noisy. 15 seer because it is still a single stage compressor and not as complicated or expensive as the 16-21 seer ac units. Pricing for what I described really depends on the area. At my company, it would probably be around $10-12,000 if you go with a higher seer you will definately need the variable speed motor and pricing wil be anywhere from 13-15,000. Unless you get a goodman which I wouldn't do(up here we call it good junk). Trane is ok except trying to clean the outdoor coil. It is a shreaded aluminum coil and once impacted with dirt you will have to uncase the coil and use an acid based coil cleaner. It's a bad time. You should also consider a good filtering system if you are going to spend the money. |
system pricing
Thank you for your thorough response. The advice was so comprehensive and sensible that (brace yourself) I am going to follow it. Good luck in your own pursuits, and thanks again.
No2Son |
sounds high
| All times are GMT -4. The time now is 01:12 PM. |
