-   -   switching from Honeywell to Totaline (http://www.diychatroom.com/f17/switching-honeywell-totaline-8327/)
novadude 05-08-2007 09:15 PM
Hi, Greetings,
I purchased a Totaline Wireless Thermostat System for our 2 year old son's bedroom last October. the original themometer setting for the heat pump upstairs is like this:
http://www.picpile.net/ims/pic_4174GOLE/16657.jpg
I replaced it with the Totaline and the new connection is like this:
http://www.picpile.net/ims/pic_4174GOLE/16658.jpg
It worked well for the whole winter. But currently, the AC won't turn on. I bet I didn't get the wires connected correctly since when I switch back to wired thermostat, it works just fine. (on the Totaline, I was told <by one HVAC guy on the phone> to leave the black wire open and I'm not sure if that caused problem). On the original panel, the E connects BLACK WIRE, There is no "E" on the Totaline.
If you know how to correct my mistake, I would greatly appreciate it.
Thank you for your help!
#CARRIERMAN 05-11-2007 07:55 PM
Hi novadude
Look at my post called Facts about thermostats. Need any help past that let me know and I will get back with you ASAP.
Good luck
Rusty
novadude 05-13-2007 09:09 PM
RE: switching from Honeywell to Totaline
Hi, Carrierman,
Thank you very much for your input.
I studied your post about the "Facts about thermostats", it is very well written and very clear about those use of "switches". But it seems I couldn't find the solution to my puzzle in that post.
I believe that 5 wires I got are correct (I only have a little bit doubt on the Orange wire because on my new panel, B,O and W1 are one connector and Orange goes there). On the new panel, I left Yellow and Black out since I was told to do so <by an HVAC guy on the phone>.
I now have big question now about this Black wire and Yellow wire. Are they really supppse to connect nothing? I have a feeling that those two wires are giving me trouble.
In additional to the pictures I gave above. There is another "dip switch panel" on the panel board, that has 9 switches and the manual indicates "1,2,4,8,16,32,EH,HP,O/B". I was told last October (by the same HVAC guy) to switch "HP"(heat pump) to ON and the rest "OFF". Do I need to turn the "HP" back to OFF? Do I need to do anything about EH, and O/B switch?
Thank you very much!
