Old 01-01-2007, 07:27 PM   #1
Switch over temp
I have a Trane heat pump with gas backup and was wandering how to tell if system has this feature or how can I tell what it is set at. Now all I know to do is to set thermostat to Emergency heat if I want gas to come on I thought the installer told me that the if the temp is greater than 2 degrees it will kick over to gas until temp is made up and heat pump comes back on, but it sounds more efficient if gas would come on at say 32 degrees ir so. The furnace I have is a XL 90 propane furnace and xli 14 heatpump. Where would on system to find this setting. Any help would be appreciated.
walker45 is offline   Reply With Quote
Old 01-01-2007, 07:53 PM   #2
Thoroughbred Mopar Man
Switch over temp
Hi walker45
Not sure what control or thermostat your system is using. Carrier has a thermostat that is called a thermidistat that you can set you changeover temp in. The other method of doing this is with an outdoor stat mounted in the heat pump. Either way it will be more energy efficient to run the heat pump at least down to 35 deg. The only one thing you dont want to ever happen, is the gas furnce coming on at the same time as the heat pump. To find all this out you will need to check with the installing company to see what type your system is.
Good luck
Rusty
#CARRIERMAN is offline   Reply With Quote
Old 01-01-2007, 10:54 PM   #3
Switch over temp
There is a "outdoor thermosstat" located in , were else ? the out door unit, it can be set from -40 to 80 degress
acefurnacefixer is offline   Reply With Quote
Wiring double switch for new ceiling fan toolmanwannabe Electrical 17 11-15-2011 10:34 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
Help a hungover guy clear his head. 3 way switch with pic J187 Electrical 10 11-10-2006 09:10 PM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 04:52 PM
Detached garage adding a 3 way switch. Slatherd Electrical 4 01-02-2006 03:53 PM
