Switch From 16 X 25 X 1 Housing To 16 X 25 X 4 Housing? - HVAC - DIY Chatroom Home Improvement Forum
Old 04-01-2013, 08:05 PM   #1
Rewards Points: 20
Question
Switch from 16 x 25 x 1 housing to 16 x 25 x 4 housing?
Hi Everyone.
Narrowed down a spider problem to a 3 inch pipe that's beneath (yes) the big elbow that brings the cold air return to the filter housing, to the furnace.
I've seen 4 inch filters strongly recommended on numerous occasions in these forums, and since I have to take the elbow off to seal that darned hole with a backflow stopper (new home, builder probably screwed up and figured I'd never see it since the drain is a few feet away) - I figured I'd tackle switching the filter housing to accommodate wider media at the same time.
Here's where I'm stuck, I went to Home Depot and Lowe's to look for a filter housing in the HVAC section and they both have no such beast. Is this a super complex job? Or have the HVAC blackballers got the big box stores in a squeeze to fence off the filter housing service industry!
Thanks for any guidance you can offer!
JustChecking is offline   Reply With Quote
Old 04-01-2013, 08:11 PM   #2
An old Tradesmen
Rewards Points: 6,824
Not something that is commonly done by most home owners. So the big box stores don't carry them as they would be slow movers. And take up valuable shelf space. You can order then on line.
Old 04-01-2013, 09:10 PM   #3
Rewards Points: 20
Thanks for chiming in! I did check online, but am having a tough time finding the right part. I'd found this one (P102-FHG1625-6) from totaline.com but seems they'll only sell to businesses. (http://www.totaline.com/dl/PAGE%20F3...20HOUSINGS.pdf)
Anyone here a totaline dealer willing to ship?
Thanks.
Old 04-01-2013, 10:24 PM   #4
Roofmaster
Rewards Points: 2,172
Have you priced the 4 inch filters yet. Got a couple arms and legs you dont need?
Old 04-01-2013, 11:10 PM   #5
Experienced HVAC Tech
HVAC1000's Avatar
go to Johnstone supply they are having a sale on Honeywell 4 inch filter housings this month plus they sell to anyone contractor or homeowner
HVAC1000 is offline   Reply With Quote
Old 04-02-2013, 04:24 AM   #6
An old Tradesmen
http://www.pexsupply.com/White-Rodge...abinet-16-x-25
Old 04-02-2013, 04:25 AM   #7
An old Tradesmen
They cost more. But they also filter better, and allow better air flow, along with last longer then a 1" filter.
Old 04-02-2013, 05:05 PM   #8
Rewards Points: 29
Alpinehomeair.com also sells them.
jsmith929 is offline   Reply With Quote
Old 04-02-2013, 10:15 PM   #9
biggles's Avatar
get some 4" sheet metal channel and make your own..$$$ on something else
Tags
filter , furnace
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 07:25 PM
A few wiring questions on installing this timer switch thinksincode Electrical 19 03-04-2013 05:31 AM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
4 way switch confusion Richo Electrical 10 04-09-2009 07:11 AM
