Surge Protection, HVAC - HVAC - DIY Chatroom Home Improvement Forum
Old 06-11-2012, 09:50 AM   #1
Surge protection, HVAC
Hi all,
I'm new to the forum and new to home ownership as well. I live in Durham, NC area so needless to say it's pretty hot this time of year, and most everyone has their AC running. On Saturday we went out to dinner and when we returned I noticed that it felt quite hot in the house. I went to the thermostat and turned it down a bit but nothing happened. I then went outside and noticed that the breaker had been tripped so I reset it, but, the AC, nor the blower, would run.
On Sunday our HVAC person came by and it took him about 2 minutes to look at the (I might have this name wrong) circuit board or electrical board, and notice that it had been fried. In one place it was just charred, completely.
Obviously the board needs to be replaced, and I talked to him about what happened and he said that it was likely a surge - could have come from the power company, etc. So then I asked him if it was possible to prevent those surges - was there anything that I could do to protect myself from this happening again - he said that he doesn't see this too often and that really, no, there wasn't too much I could do.
My unit is '99 Comfortmaker - gas furnace and AC unit combined, and he said it's a pretty simple unit; main components being the heat exchanger (I just replaced the heat exchanger), the blower, the electrical panel and the compressor. I'm throwing this in there because in some of the research I've done I noticed that most new units are a bit more complex and sometimes include delays, which keep the unit from trying to turn back on after a power outage.
Honestly, I'm so new to all of this that I just don't know what to do - obviously I'll replace the circuit board, which is being done today - it's about a $450 repair - but should I worry that this will happen again? Our repair person is someone I trust, and he said it was likely a fluke, but like most folks I'm not in a position to handle a $450 fluke whenever the power company has a surge! Is there something I can do to reduce the risk of a surge?
Thanks very much,
Max
whelmed is offline   Reply With Quote
Old 06-11-2012, 12:00 PM   #2
Your tech is right, there is not much you can do. Theoretically of course you can put some sort of surge protector in there, but tell you the truth, I have never seen any one did that.
clocert is offline   Reply With Quote
Old 06-11-2012, 12:22 PM   #3
Rewards Points: 12
When I installed my new furnace (York YP9C) I was worried about a surge damaging the board so I installed a SYCOM SYC 120HW in the furnace power supply and a SYCOM SYC 120/240-T2 in my houses main panel.
I am not sure how much good it is doing but it gives me some peace of mind.
m_peterson6 is offline   Reply With Quote
Old 06-11-2012, 07:15 PM   #4
An old Tradesmen
Rewards Points: 6,476
Then its doing a lot of good. can't have comfort without piece mind.
Old 06-11-2012, 07:24 PM   #5
Rewards Points: 6,652
Even if you install a Whole house surge protector, it is only as good as the earth ground, and the rest of the electrical system, but the catch is, that it will not protect from a direct strike, that is what your Home Owner's Insurance is for.
Old 06-12-2012, 09:51 AM   #6
Thanks!
Thanks very much for your responses. It sounds like my repair tech. had the right idea; I just worried that every time a surge happened, which seems like something I can't prevent, I'd blow another circuit board!
Peace of mind is definitely worth a lot, but if installing a whole house surge protector isn't going to do a lot, I'll cross my fingers instead!
Thanks again.
Old 06-12-2012, 05:03 PM   #7
Except for lightning, a high voltage/short duration surge likely does not contain enough energy to char anything, but it could have caused a component to short which then caused heavy current to flow. I'd think charring a circuit board like this takes a pretty big dump of energy.
Old 06-14-2012, 04:21 PM   #8
Rewards Points: 77
Look into voltage monitors, ICM491 or ICM492
Filtration / HVAC & Indoor Air Quality Solutions
AirstarFilters is offline   Reply With Quote
Old 06-15-2012, 08:52 PM   #9
Rewards Points: 150
If by '99 you mean 1999, you could ask the tech to eliminate the circuit board, replacing it with old school (and cheap) parts. It's not rocket science, but it would need to be done by someone who knows what they're doing. It shouldn't take much longer than replacing the board. $450 sounds a bit high to replace a board.
rightit is offline   Reply With Quote
Old 06-15-2012, 09:34 PM   #10
An old Tradesmen
A circuit board that controls both the A/c and gas heat in a package unit is not easily or cheaply replaced by other relays and components.
Old 06-15-2012, 10:13 PM   #11
Rewards Points: 150
Yes, gas heat does complicate matters a bit. Thanks for the remarks.
Tags
hvac circuit board , surge protector
Whole house surge protection, help.... Ralph III Electrical 59 01-31-2012 01:37 PM
surge protection for recessed power plug? 205bhamjim Home Theater 2 04-20-2010 12:21 AM
Surge Protection Outlet yellowrubiu Electrical 5 02-02-2010 10:09 PM
Surge Protection in Travel Trailer??? Spike99 Electrical 7 08-07-2009 10:37 PM
Whole House Surge Protection? Ultrarunner2017 Electrical 15 02-04-2009 10:39 PM
