Old 08-03-2012, 09:42 PM   #1
Suppy line below ceiling
Need to get this above ceiling level. Where do I begin?
ey218 is offline   Reply With Quote
Old 08-03-2012, 09:43 PM   #2
Another photo.
Old 08-03-2012, 09:44 PM   #3
Return is above ceiling level.
Old 08-04-2012, 05:40 AM   #4
There's really no way for us to give advice on this - you need someone to come out and see what you're dealing with.
Do you have enough room in the ceiling cavity to move it up there? If you do, then it shouldn't be a big deal to do it - but it must be done correctly, else you'll end up with airflow issues.
Are you concerned about head space, or just want to hide it? If you just want to hide it, box around it with lumber, sheetrock it, and paint.
scottmcd9999 is offline   Reply With Quote
Old 08-04-2012, 07:45 AM   #5
biggles's Avatar
if the ducting is the same age as the house most likely there is no room or the installer would of hid it
Old 08-04-2012, 08:13 AM   #6
What's above the ceiling,attic or another level?
Old 08-04-2012, 10:44 AM   #7
I believe it is post construction duct work. Also, there is a living area above. The return is above ceiling level. I guess my real question is what size duct work do I have to use for the main supply line?
Old 08-04-2012, 02:40 PM   #8
The duct is 6 1/4" x 14". Depth of floor board b/w ceiling is 7 1/2". I believe there is room to move it up rather than put up soffit. I'd like it out of site.
Is it a DIY job or should I bring someone in?
Old 08-04-2012, 04:17 PM   #9
Need to know size of system to coment on duct sizes (a/c size heat type and size). If currently working then one would assume it is sized correctly but who knows. If you have room for it above the ceiling than you could put it in there. It will need to be insulated once it goes above the ceiling.
turnermech is offline   Reply With Quote
Old 08-04-2012, 04:51 PM   #10
Brand new system installed 2 years ago. Don't have the numbers and am away from the house,
Old 08-04-2012, 06:07 PM   #11
Gas furnace... Sorry
Old 08-04-2012, 11:30 PM   #12
Here's a pic of the Goodman. What #'s do you need to know?
Old 09-02-2012, 09:07 AM   #13
I spoke with several GC's and an HVAC guy. They say 3.25" x10" is fine. Now I have to figure out the rest and I'm sure I'll be coming here for more help
Old 09-02-2012, 03:41 PM   #14
fine for what?
to replace that duct with?
3.25x10=32.5 sq in
6.25x14 87.5 sq in
Old 09-02-2012, 03:57 PM   #15
An old Tradesmen
How many rooms does that trunk line at that point serve?
Popcorn ceiling with asbestos - options? 30Five Drywall & Plaster 6 02-21-2012 10:27 PM
Plaster ceiling with peeling paint annaem Painting 14 01-19-2012 01:10 PM
What to do with this old ceiling? mudworm Building & Construction 4 07-17-2011 05:54 PM
My ceiling moves in a wave pattern and not in a even line, I do not know how to fix. TheUnhandyman Drywall & Plaster 4 01-19-2010 11:40 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
