Supply Plenum Vertical Takeoff? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-02-2010, 01:21 PM   #1
Supply plenum vertical takeoff?
Hi guys, hope someone can help, I will try to be as thorough as possible.
I have added a second floor to my house, I have the main trunks in place. Due to the location of the furnace (duct work for basement and 1st floor are existing, I am changing the furnace to a larger one, all load calculations have been done and everything is sized properly) the way everything lines up the I can't really use a plenum take off but would have to use a reducer to go vertical out of the top. is this allowed? I have checked a few near me but they all have a main plenum box attached to the furnace with 2 plenum takeoffs tying into the horizontal ducwork. I am also going to install volume dampers for balancing if that makes a difference. plenum is 20x20 the vertical duct is 16x10
dhubz is offline   Reply With Quote
Old 11-02-2010, 07:38 PM   #2
An old Tradesmen
Rewards Points: 6,904
A 20X20 to 16X10 transition is fine. make it 2' or longer. And it won't hurt air flow.
Supply valve to bath faucet doesn't stop water Kurt123 Plumbing 2 09-05-2010 09:48 PM
how to make takeoff on flex supply duct jimmy anderson HVAC 4 07-19-2010 10:02 AM
Extending Water Supply Box In Laundry Room hsl Building & Construction 0 11-18-2009 09:21 AM
How tall should I make my supply plenum box? super77 HVAC 2 08-01-2008 09:26 AM
Removing Extended Plenum Calm_Blue_Ocean HVAC 15 01-07-2008 05:22 PM
