Old 11-28-2012, 11:52 AM   #1
Supplemental heating for garage
Hi all,
In our garage we have a vent connected to the furnace. I currently only let a trickle heat out, cause I am concerned about off gases from the car entering the house from the vent.
Would it be beneficial to spend a few hundred dollars to install a 240V 5000W heater with a thermostat? Set it to 65F. So when the garage door opens and the temp drops very quickly (in Canada winter), this heater can quickly bring back the temp. Would it also be beneficial to the bedroom above?
Thanks!
Terry
tls1 is offline   Reply With Quote
Old 11-28-2012, 12:04 PM   #2
Only you can answer whether the cost is beneficial to you.
And yes, the warmer it is in garage, it will be beneficial to a bedroom located above the garage.
hammerlane is offline   Reply With Quote
Old 11-28-2012, 05:12 PM   #3
An old Tradesmen
Seal off the vent. Code prohibits it in a garage when the rest of the duct work connects to the house.
What is a good efficient heating system for cold climates? reveriereptile HVAC 7 02-08-2012 09:26 PM
Radiant floor heating questions secutanudu HVAC 35 03-08-2010 02:04 PM
Hydrokientix Heating System Not Heating damonl73 HVAC 11 12-18-2009 06:12 PM
Electrical consumption of baseboard heater CowboyAndy Electrical 7 03-24-2008 08:27 PM
Central Heating Frustration SassySue General Discussion 4 11-29-2007 07:46 AM
