Superheat Subcooling Question - HVAC - DIY Chatroom Home Improvement Forum
Old 09-04-2012, 04:37 PM   #1
Rewards Points: 66
Superheat Subcooling question
I know that you need to know this as a tech in order to correctly diagnose a system. I know that a fixed orifice system uses suberheat and TXV uses subcooling.
So my dumb novice question is:
Since its possible that to have either, is this a brand specific thing?
or
is this an installer decision for efficiencey?
My sons Bryant exterior label has a subcooling of 11 noted, but on the inside it has a superheat chart.
Because obviously the first thing a tech must do is determine this, correct?
digitalplumber is offline   Reply With Quote
Old 09-04-2012, 08:02 PM   #2
An old Tradesmen
Rewards Points: 7,344
Always determine by what type of metering device it has.
Old 09-04-2012, 09:11 PM   #3
Rewards Points: 66
So the answer is its not brand specific and the tech must go look at the EVAP coil first.
Old 09-05-2012, 11:52 AM   #4
raylo32's Avatar
Rewards Points: 1,284
And then look at the condenser label plate to see if it specifies the subcooling for if there is a TXV in the evap coil. When I upgraded my old leaking fixed orifice coil to one with a TXV I noted that my condenser gave the subcooling spec. I think there is a rule of thumb around to set it ~10 degrees but my condenser (Carrier) specified 20. So 20 it was when I adjusted the charge.
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 09-05-2012, 12:21 PM   #5
Rewards Points: 66
Thanks makes sense
digitalplumber is just a name for use here, I am not a plumber!
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
