-   -   Superheat Subcooling question (http://www.diychatroom.com/f17/superheat-subcooling-question-155848/)
digitalplumber 09-04-2012 04:37 PM
I know that you need to know this as a tech in order to correctly diagnose a system. I know that a fixed orifice system uses suberheat and TXV uses subcooling.
So my dumb novice question is:
Since its possible that to have either, is this a brand specific thing?
or
is this an installer decision for efficiencey?
My sons Bryant exterior label has a subcooling of 11 noted, but on the inside it has a superheat chart.
Because obviously the first thing a tech must do is determine this, correct?
beenthere 09-04-2012 08:02 PM
Always determine by what type of metering device it has.
digitalplumber 09-04-2012 09:11 PM
So the answer is its not brand specific and the tech must go look at the EVAP coil first.
raylo32 09-05-2012 11:52 AM
And then look at the condenser label plate to see if it specifies the subcooling for if there is a TXV in the evap coil. When I upgraded my old leaking fixed orifice coil to one with a TXV I noted that my condenser gave the subcooling spec. I think there is a rule of thumb around to set it ~10 degrees but my condenser (Carrier) specified 20. So 20 it was when I adjusted the charge.
digitalplumber 09-05-2012 12:21 PM
Thanks makes sense
