SuperHeat & Subcooling - HVAC - DIY Chatroom Home Improvement Forum
Old 03-04-2011, 04:29 AM   #1
JJboy's Avatar
Let me know what do you think?
http://www.keepandshare.com/doc/2640...7-am-703k?da=y
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 03-04-2011, 07:36 AM   #2
Why do I have to sign into something? What is this
Hubcap626 is offline   Reply With Quote
Old 03-04-2011, 01:04 PM   #3
JJboy's Avatar
It's a pdf file. I did not know you would have to register to see the file. I'll have to find another place to put this file pdf.
Old 03-04-2011, 01:07 PM   #4
Experienced
Jackofall1's Avatar
JJ just copy the web address the file is in with the file open, and then paste that address into the post,
Mark
Old 03-04-2011, 01:10 PM   #5
JJboy's Avatar
Ok, I think I found the right place to share this file.
https://docs.google.com/viewer?a=v&p...MWE5ODdl&hl=en
Old 03-04-2011, 05:46 PM   #6
The superheat looks good. Using outdoor temp +30 to get a target subcool is going to get you in trouble . Lots of the high SEER equiptment specifies subcool in the 5-8 range.
Old 03-04-2011, 05:49 PM   #7
JJboy's Avatar
Thanks for the review Marty S. How do you do to calculate subcooling?
Old 03-04-2011, 07:00 PM   #8
Most of the stuff I work on is Lennox and it has the desired subcool printed on the unit label or in the instructions. The same unit might show 8 different target subcool numbers depending on which coil was used.
TXV and superheat DIY_HVAC HVAC 39 12-31-2011 07:23 AM
Goodman heatpump subcooling too high Rollie HVAC 4 01-06-2011 11:27 AM
superheat -1 wetbar HVAC 30 07-21-2010 05:49 PM
superheat cheld HVAC 2 05-24-2010 06:22 PM
