Summer Vs Winter Ac Install Cost - HVAC - DIY Chatroom Home Improvement Forum
Old 06-17-2009, 05:10 PM   #1
Summer vs winter ac install cost
Does the cost of installing/replacing an ac system vary much by the season? I'm guessing it would be cheapest in the spring and fall when nobody is using either heat or ac, and contractors are more desperate for work.
peterk is offline   Reply With Quote
Old 06-17-2009, 05:30 PM   #2
Home Air Direct's Avatar
Your assumption is basically correct across the trade, but not in every case. Crisis management can be more expensive. If it is 95 degrees, the contractors will more than likely be backed up with service calls and immediate installs. The likelihood of being able to negotiate an install price under these conditions is slim.
Also, beyond the economics of your project is the fact that AC install is better for you when you and your family are not personally inconvenienced by being without cooling for a day or two.
Winter is not out of the question, but the biggest issue is that to properly start up a new AC system, you really need a warm day (65+), and this usually requires a return trip for the installing contractor in the spring for final start up and that can add to their expense.
Good luck to you with your project.
Settle down! If you were that important, the city would give you lights and a siren for your car
Home Air Direct is offline   Reply With Quote
Old 06-17-2009, 07:01 PM   #3
HVAC / Plumbing
I don't charge anymore or less in the winter/ spring, summer, fall. My prices are the same for all seasons
kenmac is offline   Reply With Quote
Old 06-18-2009, 08:51 AM   #4
In part that is true, but regardless of cyclical labor costs, the manufacturers do have a tendency to offer rebates to clear overstocked inventory.
dac122 is offline   Reply With Quote
Laminate floor installation price mt232 Flooring 24 11-05-2011 10:35 AM
Need to install a water pressure regulator Doug Crf Plumbing 2 06-20-2009 01:23 PM
Price quote for Marvin and Install. Opinions please. dignan99 General DIY Discussions 5 06-10-2009 08:00 AM
Install geothermal myself? ToddDaniels HVAC 27 05-30-2009 08:57 AM
cutting shingles to install gutters Chicago Bill General DIY Discussions 2 02-27-2009 05:42 AM
