Old 03-17-2008, 12:40 PM   #1
Summer moisture odor in basement
I am concerned that there is too much moisture building up in my basement during the warm summer months. I was told instead of getting just a dehumidifier for the basement, I should get a Thermastor Ultra Aire that has a capacity of up to 3000 sf. I have another option of going with an Air Handler with a humidistat and dehumidifier with a 1 1/2 ton condenser to do the same thing at a lot less a price. Any one know the difference in the two and can offer me any advise??
pwaxman is offline   Reply With Quote
Old 03-17-2008, 12:50 PM   #2
It might be better to address how the moisture is getting in first. Can you describe the construction of your basement and what moisture problems you're having?
Old 03-17-2008, 01:09 PM   #3
I think it is just normal humidity build up.. It doesn't exist in the winter at all.
we have concrete, cinder blocks and wood frame, built around 15 years ago. There is no water seepage or anything like that. It really seems weather based.
Old 03-17-2008, 06:50 PM   #4
Electrician
I bought one of these units, does the whole house, very nice.
http://www.iaqsource.com/product.php...FRUvlgodxEy6lw
chris75 is offline   Reply With Quote
Old 03-17-2008, 07:57 PM   #5
thank you Chris- that makes me feel more reassured!!
Old 03-17-2008, 08:04 PM   #6
Electrician
Its expensive, but it works very well, you can also try the name brand Santa Fe Dehumidifiers... might be a little cheaper. Also shop around... I only paid 1000 when I bought mine...
Old 03-17-2008, 08:38 PM   #7
What brand- I was quoted on the Ultra Aire 90-H at over $4,000!
Not including any electrical work that may be required. THe basement square footage is only about 600sf for the part that is affected.
Old 03-17-2008, 08:46 PM   #8
Electrician
I paid $1000 for the Aprilaire, but the Santa Fe should be right around the same price, I did the install but it was pretty easy for my configuration.
Old 06-05-2008, 09:49 PM   #9
time to do a moisture test
ro9beam2002 is offline   Reply With Quote
Basement remodel, I need help figuring out moisture problem hampton72 Remodeling 1 03-07-2008 11:30 AM
hot water heat attic central air...hot basement in summer spttrac214 HVAC 2 02-29-2008 06:24 AM
Moisture in walkout basement after rain storm dannox02 Building & Construction 2 01-24-2006 01:45 PM
Plan for solving basement moisture problem krx Remodeling 1 12-04-2005 08:00 PM
