Summer Cooling With A Heat Pump - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-11-2011, 07:28 PM   #16
JJboy's Avatar
How do you know compressor was shut down?
Keep AC running until stop and ask the technician to show up this time. He needs to check high pressure.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 08-11-2011, 07:40 PM   #17
For sure post up what the results are. If the compressor stops in the heat of the day but the outside fan keeps running it's probably low on refrigerant. Not a lot low but just enough the compressor overheats with the constant run times.
Old 08-11-2011, 07:48 PM   #18
An old Tradesmen
Rewards Points: 6,148
Yep, post the results.
Old 08-19-2011, 05:44 PM   #19
Well, finally, a week later..... A new technician came out and used his gauges and declared the coolant to be "perfect." He poo-pooed the other guy's idea about cooling down the objects inside and said, since the thermostat is very sensitive, it's not good to bump the setting up when it starts to not cool anymore. Just leave it alone, that it's designed to do what it was doing and eventually it would start cooling again. He suggested a more reasonable setting of 79 or 80 degrees. This week it's "only" been up to about 105 outside, and actually, it seems to be cooling very well. Kept it at 79 with the exception of a few minutes one day when it went up to 81. So, I don't know if he adjusted or even bumped something, or if it's just the cooler weather. Thanks to all of you for your comments. They definitely guided me through this.
kikoanne is offline   Reply With Quote
Old 08-19-2011, 06:48 PM   #20
Rewards Points: 338
it sounds like something is up, probably a bigger problem. yeah, it's hotter than hell in texas right now, but if the unit just simply can't keep up and the load on it is too high, the compressor may be shutting down due to thermal overload. the technician needs to do a proper wet bulb/dry bulb target superheat/subcooling compared to actual subcooling/superheat, depending on whether it is TXV or fixed orifice. i call b.s. on both technicians, something is not right. my unit runs just fine in this heat and keeps running. i'm a novice and i would have checked more than that guy.
NitroNate is offline   Reply With Quote
Old 08-19-2011, 09:36 PM   #21
i agree, times are hot here in texas (laredo) but that a/c unit should STILL be able to cool ur house down pretty well.
one thing that came to mind JUST now, ur outside unit wouldnt happen to be located under a part or side of the house where it would suck in the hot air that it is ejecting through the top, would it?
post pics if you may
Final Notice is offline   Reply With Quote
Heat pump vs. Radiators - Opinions/Recommendations rflail HVAC 7 11-10-2010 10:56 PM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 01:19 PM
heat pump question David from MD HVAC 3 02-01-2010 09:42 PM
heat pump cut off set point oldswab HVAC 4 12-02-2009 03:09 PM
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 01:27 PM
