Summer Cooling - HVAC - DIY Chatroom Home Improvement Forum
Old 07-25-2010, 06:28 PM   #1
summer cooling
Need info on summer setting for a Freedom 80 furnace model #AUD120C954J1. The tags don't tell me how to run the blower for summer cooling. It is electronic ignition.
donmalchow is offline   Reply With Quote
Old 07-25-2010, 06:33 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 136
Post a closeup pic of the circuit board. If you have a heat/cool thermostat and proper wiring then you can turn the fan on. If not I can give you a alternate cheap wiring solution if you have some electrical skills.
The Following User Says Thank You to yuri For This Useful Post:
donmalchow (07-26-2010)
Help! Just changed my Fan Controler (ICM 275) now system "false starts" when cooling redmachodevil HVAC 4 01-26-2011 03:21 AM
Wiring a Ruud RGTK-06E series furnace for 2-ton cooling bolo_invictus HVAC 3 01-25-2010 03:24 PM
Installation of Honeywell Thermostat - cooling function KDW Electrical 0 10-04-2009 09:56 AM
Geothermal cooling loop help stuartm HVAC 2 09-29-2008 10:18 PM
Heat Pump/AC not cooling, new home eshipler HVAC 7 07-25-2007 08:52 PM
