Summer Is Coming, Whole House Fan - HVAC - DIY Chatroom Home Improvement Forum
Old 03-11-2009, 09:29 PM   #1
Speedbird's Avatar
Summer is coming, Whole House Fan
I am adding whole house fans and to reduce the noise I am ducting the air from the intake register to the 2 fans 15' away in the attic. I intend to connect the intake register to the fans via 2 x 14" flexible duct. I need to make 2 x 45 deg turns on each fan. Airflow is 1600 cfm/fan. Is this going to reduce my airflow in any significant way?. Obviously I want max airflow.
Thanks to the group.
Speedbird is offline   Reply With Quote
Old 03-11-2009, 09:41 PM   #2
An old Tradesmen
Rewards Points: 7,344
Might want to check, what static pressure the fans are able to work against.
Will each fan have its own back draft damper. They each need their own.
Old 03-12-2009, 05:05 PM   #3
Don't have the fan so large that it steals combustion air from gas-burning appliances in your house.
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
Moving a House 70 miles- Practical? GOTHICrevivalRULES Building & Construction 19 11-27-2008 08:58 PM
Water coming in the house and a leak laarni General DIY Discussions 5 07-26-2008 06:19 AM
Suggestions to winterize summer house Jim Martin PA Plumbing 2 10-23-2007 07:32 AM
