Old 05-05-2010, 09:55 PM   #1
Summer boiler temp question
I have a oil burner with a water heater. I read somewhere here that in the summer I could lower my hi / low setting because the boiler will not have to produce heat for the baseboard heating. If so what is a good hi/low setting . My water heaer is set at 120. Thanks
dontilgon is offline   Reply With Quote
Old 05-06-2010, 06:14 AM   #2
Licensed Master Plumber
The boiler should be wired so that it only fires when the water tank calls for heat.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 05-06-2010, 07:30 AM   #3
An old Tradesmen
Do you have a water heater and a boiler.
Or a boiler with a tankless coil, or an indirect water heater attached to the boiler.
Old 05-06-2010, 01:37 PM   #4
I have a water heater and i believe a tankless coil boiler that has been disconnected. Does this pic help
Old 05-06-2010, 05:51 PM   #5
tk03's Avatar
The control should have been changed to a cold start control which means a high limit setting only when the indirect water heater was installed. This means the boiler will only run when you have a call for heat or for hot water. The down side is the gasket may drip a bit when the boiler goes cold. I would replace the coil with a blank plate and new gasket.
If you don't want to do this due to expense than lower the low side as low as it goes with a 25f differential setting. Do not turn it up in the winter. Keep the high limit at 180 - 200. This only comes into the picture when there is a demand.
tk03 is offline   Reply With Quote
Old 05-06-2010, 06:05 PM   #6
The control still has a low high and dif setting. And u are right about the leaking but only when it gets below 100. Where would i buy a blank and gasket for this boiler. Also Iam little confused on what you suggested. Why do i need to keep the boiler hi at 180 if when the water heater calls for water its set at 120 at the water heater. Does this make sense
Old 05-06-2010, 06:27 PM   #7
An old Tradesmen
Your water heater doesn't have a burner, does it.
If not, its a indirect water heater. that uses your boiler to heat the water.
You may be able to set the boiler temp lower. Depends on how much of a hot water demand you have.
If your indirect is set to 120, the boiler needs to be set higher. So that it can heater the water to 120.
Old 05-07-2010, 03:24 PM   #8
Looks to me like he's got a tankless coil in the boiler which means the temperature can't be lowered much past 160
Old 05-07-2010, 03:31 PM   #9
An old Tradesmen
Tanklees is disconnected.
You can see that there is no pipe connected to the mixing valves mixed water port.
And what look like an Aliance indirect is also in the room.
Boiler room/air make up question joeg679 HVAC 3 11-16-2009 05:44 AM
Boiler install questions ICBM HVAC 0 11-03-2009 02:49 PM
Outside water boiler shutdown hillardl Plumbing 2 03-20-2009 06:27 PM
Tankless coil in oil-fired boiler lebeld Plumbing 4 01-18-2009 09:48 AM
question about cleaning a boiler room Piratehart General Discussion 1 02-14-2006 01:58 PM
