Suitable Replacement Motor? - HVAC - DIY Chatroom Home Improvement Forum
Old 06-24-2009, 03:47 PM   #1
Suitable replacement motor?
Hi new to HVAC here. My condenser fan motor is shot and old i could not find an exact match for the specs so i would like to know if the new motor is a suitable replacement for the old
OLD: 208-230V 60Hz 1/6hp 1110rpm 1.0A 5mfd370vac capacitor
NEW: 208-230V 60Hz 1/6hp 1075rpm .8-.9 full load amps 3mfd370vac capacitor
i may be wrong about the capacitor on the old motor the motor info tag was a little worn
Grainger item # 4uy74 is the motor match that was given when i entered the specs of my old one
Also can i reverse the fan rotation by switching the leads if i need to?
Thanks, mike
randolph1012 is offline   Reply With Quote
Old 06-24-2009, 05:20 PM   #2
The RPMS of the new motor is close enough where it shouldn't be a problem. The only thing I would be concerned with is if the motor pulls a full AMP you may have a problem. Typically they pull .5 AMP or less. I would try it.
SKIP4661 is offline   Reply With Quote
Old 06-24-2009, 06:09 PM   #3
biggles's Avatar
the new motor should be cw/ccw or either on the motor tag info
Old 06-24-2009, 07:28 PM   #4
alright thanks guys i went ahead and ordered a comparable motor to grainger's item. hopefully next time i post i'll be claiming victory!
Old 06-24-2009, 09:04 PM   #5
A condenser motor has to withstand a 130F airstream, or not?
Replace Condenser Fan Motor cnavazio HVAC 14 06-24-2009 09:57 PM
Oiling Trane XB1000 AC Fan Motor Build HVAC 5 06-19-2009 04:05 PM
Motor control wiring problem dgr68 Electrical 8 01-04-2009 05:13 PM
Trane XE 80 vent motor replacement DJfixer HVAC 3 12-26-2008 02:15 PM
Replacing a Condenser Fan Motor thothtp HVAC 5 06-08-2008 06:30 PM
