Suggestions For Electric A/c Usage - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-24-2011, 07:26 PM   #16
An old Tradesmen
Rewards Points: 6,148
Originally Posted by gregzoll View Post
Using a Heat Pump for costs on electric depends on the provider. A Heat Pump is not going to magically make your costs for use of electric or gas automatically go down. A heat Pump costs the same to use, as using a AC & Furnace. If you believe the hype that a heat pump is more efficient, than a high efficient 91% or better furnace & 16 SEER or greater A/C, it is false info.
Your incorrect.
I have heat pumps in dual fuel applications where the gas furnace is a 95% efficient furnace, and the heat pump heats the house for less money then the gas furnace can at any temp above 20F. And on some of them, as low as 15.
I have some dual fuel set ups that the gas heat is a boiler. And the heat pump runs even when its 0F outside, and they save on their heating bill with both the heat pump running and the gas boiler. They use very little gas for heating, the heat pump does the majority of the heating, and their monthly electric bill and gas bill combined is less then what their monthly gas bill use to be when the gas boiler did all the heating.
help for gas usage Amy28 HVAC 1 04-27-2011 05:39 AM
Suggestions for my Kitchen ktm General DIY Discussions 7 04-08-2011 09:13 AM
Cheap suggestions for changing look of bathroom sink countertop? mrdazzo7 General DIY Discussions 11 01-07-2011 06:43 PM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 06:07 PM
