Suggestions For A 5 Ton Split Heat Pump Purchase? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-07-2010, 10:41 AM   #1
Suggestions for a 5 ton split heat pump purchase?
Hi,
I am in the market for a replacement 5 ton, all-electric, split, heat pump and handler.
I am in Arizona.
What system(s) would folks recommend, please?
I would like to take advantage of the federal 30% tax credit unless the initial cost of the system eats up and benefit.
Thank you in advance,
Kurt
kurtibm is offline   Reply With Quote
Old 07-07-2010, 11:47 AM   #2
Originally Posted by kurtibm View Post
Hi,
I am in Arizona.
Kurt
The installer/contractor trumps the brand of the system.
Get the absolute best installer you can possibly find and then go with the brand that they recommend. The contractor will likely know which units will perform best for your specific requirements. They will also know how to best navigate through the various rebates/tax credits/incentives.
You also want the contractor to install equipment they are most familiar with and which they have strong distributer/manufacturer relationships with.
hennyh is offline   Reply With Quote
What temp does my Heat Pump stop producing good heat or what is the threshold? twilightcall HVAC 15 02-12-2010 09:46 PM
Fujitsu Heat Pump Concerns SanDiegoCool HVAC 3 03-19-2009 12:27 PM
Heat Pump + Aux Heat Problem - Can You Help? whitedavidp HVAC 17 12-25-2008 06:37 PM
Heat pump in non insulated nor heated room robdville HVAC 3 01-21-2008 02:51 PM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 02:11 PM
