Suddenly Heat Pump Making Rat-a-tat-tat Noise - HVAC - DIY Chatroom Home Improvement Forum
Old 12-20-2010, 01:27 PM   #1
Suddenly Heat Pump making rat-a-tat-tat noise
One of my heat pumps is suddently making an almost machine gun like sound. It was running normally, and then suddenly went into this noise. I have shut it off. Sounds like a muffler with a hole in it. Any one have any idea what this could be?
Before I call back my installers I just want some sort of feel as to what this might be so I will be more educated. I've had problems with my installers in the past and am therefore a bit fearful of them working on this unless I can speak with them about it knowledgeably.
Thanks,
Mike
mgroves is offline   Reply With Quote
Old 12-20-2010, 01:49 PM   #2
Found it...it appears that the cowling was not secured properly, probably when these jokers installed the warranty reversing valve last winter, and now the fan is hitting that cowling.
Just left this posted in case this happens to someone else.
Mike
Heat pump vs. Radiators - Opinions/Recommendations rflail HVAC 7 11-10-2010 10:56 PM
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 01:19 PM
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 11:22 PM
heat pump cut off set point oldswab HVAC 4 12-02-2009 03:09 PM
Heat elements making noise helpless handyman HVAC 17 12-06-2006 03:49 PM
