Suction Line Oil Trap - What Are The Rules? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-12-2009, 12:25 AM   #1
Rewards Points: 392
Suction Line Oil Trap - What are the rules?
When do you need a suction line oil trap? Is there a rule of thumb or a hard rule? Does it matter if the Compressor is higher or the Coil is higher?
I'm looking at about a 1.5 foot difference in height between the two..
What are you protecting, the coil or the compressor, or something else?
-Jeff
zootjeff is offline   Reply With Quote
Old 07-12-2009, 09:11 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,318
If the condensor is on a roof it needs to work harder to suck up the oil to the compressor. The manufacturer of the unit has specs for that height. Over 20 ft is necessary from what I remember (and that is fading as I get younger).
condensation on suction line SAMMY25 HVAC 9 06-03-2012 11:59 AM
ac suction line placement? nimbenja HVAC 8 10-28-2009 05:43 AM
Capacity loss with line size Einride HVAC 1 06-29-2009 03:10 PM
sediment trap with gas flex line? diggerdave Plumbing 10 02-11-2009 06:14 PM
