Suction Line Insulation - HVAC - DIY Chatroom Home Improvement Forum
Old 07-01-2011, 09:42 PM   #1
I want to replace the Insulation on the Suction Line.. After I get the Rubber insulation on the pipe can I use electrical tape and tie wraps to hold it on, or
is there a better way or specialized tape to use?
d
dbmet is online now   Reply With Quote
Old 07-01-2011, 09:58 PM   #2
JJboy's Avatar
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
http://www.homedepot.com/Plumbing-Pi...atalogId=10053
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-01-2011, 10:08 PM   #3
Thanks very much.. I knew I saw something somewhere, just couldn't locate it..
d
temperature on suction line frank otero HVAC 2 02-06-2011 04:27 PM
Trunk Line Insulation Sype HVAC 4 01-18-2011 09:44 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
Shallow wells loses prime rosberney Plumbing 20 01-26-2010 07:56 PM
