Suction Line - HVAC - DIY Chatroom Home Improvement Forum
Old 02-23-2012, 09:00 AM   #1
suction line
why is the suction line insulated
shelton65 is offline   Reply With Quote
Old 02-23-2012, 09:49 AM   #2
prevents sweating and heat gain to refrigerant which can cause compressor over heating.
hvac5646 is offline   Reply With Quote
Old 02-23-2012, 03:40 PM   #3
biggles's Avatar
from the air handler to the condenser is a heat gain then the cycle repeats itself and sweating as mentioned...so think of the hot summer sun banging that line back out without the armaflex wrap that is a load and right into your wallet with a higher suction temperature...the more it sweats the better
Old 02-23-2012, 04:00 PM   #4
An old Tradesmen
Rewards Points: 6,922
Just to prevent sweating.
If you had a 20 foot long 7/8" vapor line that had a refrigerant gas temp of 55F, and it was exposed to an ambient temp of 154F. it would only gain 1,060 BTUs of heat.
Old 02-23-2012, 04:08 PM   #5
you musta wanted to post that real bad, Been..but i think i heard the OPs head explode...
Old 02-23-2012, 05:44 PM   #6
GC/Master Plumber/Mech
Rewards Points: 560
On earth not mars .. please
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 02-23-2012, 05:52 PM   #7
An old Tradesmen
Some attics exceed 155F.
At an ambient of 123F, the same line would only gain 900 BTUs.
Old 02-24-2012, 12:22 PM   #8
Insulation actually acts as a resistance to heat rejection to and heat rejection from atmosphere. When the suction line is not insulated, the refrigerant gains heat and it gets warmer. This warm refrigerant which was supposed to enter at a lower temperature now enters at a higher temperature and thus compressor needs to perform more work than before.
fiveohthree is offline   Reply With Quote
Gas dryer - installing flexible gas line mspmatt Plumbing 11 12-30-2011 04:32 PM
Gas line for pool heater BillyDIY Plumbing 3 06-10-2011 02:29 PM
ac not cooling, suction line freezing, suction pressure in "Retard" GetYourShineBox HVAC 7 05-26-2011 09:01 PM
Can a roof vent identify where my main sewer line exits the house? YerDugliness Plumbing 8 01-26-2010 04:13 PM
sewer line Master Brian Plumbing 3 05-25-2009 12:53 AM
