Subcooling Is Way High -- Need Advice! - HVAC - Page 6 - DIY Chatroom Home Improvement Forum
Old 09-03-2013, 11:56 PM   #76
Rewards Points: 16
Originally Posted by hvac5646 View Post
Your forgetting the oil is in contact with the compressor housing and the tubing. The heat would conduct from these areas of mass to the moisture to stop a freeze from occurring.
And i wish to reiterate, this is a resi system ..not a system subject to possible flooding like a chiller or other indirect refer system.
Yeh vacuum is a good insulator...but even celestial bodies experience heat gain in outer space.
<iframe width="640" height="360" src="http://www.youtube.com/embed/ECOMAbLI1V4?feature=player_detailpage" frameborder="0" allowfullscreen></iframe>
itaintmesy is offline   Reply With Quote
Old 09-04-2013, 12:05 AM   #77
hhmmm this blows Beenthers argument out of the water.
hvac5646 is offline   Reply With Quote
Old 09-04-2013, 05:06 AM   #78
An old Tradesmen
Rewards Points: 6,836
I was talking to payson a lot when he was doing that test.
In a system you don't have that large of an amount of water sitting in one place. Just a few drops collecting here and there. And it freezes up much faster then what the video first implies.
Old 09-05-2013, 12:31 PM   #79
Rewards Points: 16
in a system you don't have that large of an amount of water sitting in one place. Just a few drops collecting here and there. And it freezes up much faster then what the video first implies.
In plain English since there is admittedly usually very minuscule amounts of water in a system under evacuation: It stands to reason that the larger volume of matter surrounding the moisture would be an enormous heat sink disallowing the moisture to phase change fusion to ice. There would be too much heat in the volume of the surrounding substance to give up that much heat to allow the change to ice.
Old 09-05-2013, 12:46 PM   #80
Rewards Points: 16
One of the basic laws of heat transfer state quite simply that heat travels from one mass of a higher temp to a mass of a lower temp until equilibrium is reached.
With that, it would be improbable that the moisture would continue to draw heat from its much higher volume surrounding with out vaporizing long before equilibrium could be attained.
The math also bares this out.
Old 09-05-2013, 02:55 PM   #81
An old Tradesmen
No clover, or 5646 which ever one you are. Only the contact area of the mass touching the moisture could transfer any heat. As a vacuum does not transfer heat.
Payson used too much water. So it doesn't show real well how water can freeze during a vacuum.
Old 09-05-2013, 03:41 PM   #82
Rewards Points: 16
There was ambient temps that contributed to. The length of time it took for the ice to form
HAd he used an insulted continued the results would have been diff.
If the anoint of water was less it would have boiled off in a closed system.
Old 09-05-2013, 04:10 PM   #83
Rewards Points: 16
That isn't what u said in an earlier post.
You said heat was conveyed by radiant transmission.
The moisture is in contact way either internal surfaced or oil.
Either of which will conduct heat from comp shell and tubing.
I would also point out that
inert gas sweeps subtracts from your argument.
Old 09-05-2013, 06:06 PM   #84
An old Tradesmen
Clover/5646.
Why are you stuck on moisture only being in the compressor.
Moisture in the line set or anywhere else WILL freeze.
Yes radiant heat can travel through a vacuum.
You saw the bid. The water froze.
Old 09-05-2013, 06:24 PM   #85
Rewards Points: 16
kkooooppp
Old 09-05-2013, 06:39 PM   #86
Clover/5646.
unless I can be in two places at the same time, you got a case of mistaken identity.
Old 09-05-2013, 06:48 PM   #87
Rewards Points: 16
kkooooppp
been there I am NOT stuck on moisture being only in the compressor, in post 82 I mentioned the entire sealed system. I think it can be assumed from that point on we were speaking of sealed systems entirely not just the compressor.
Old 09-05-2013, 06:53 PM   #88
An old Tradesmen
Then stop mentioning about the compressor.
Old 09-05-2013, 07:11 PM   #89
Rewards Points: 16
I didn'
haha. changing the subject to get away from the real issue. Pretty sly, but I don't play that.
I didn't come here to argue.
I wanted to contribute to this conversationt in your discussion with the gentleman about vacuums.
But you have mistaken me for
Some one else.
Not very fair to me isit?
Old 09-05-2013, 09:57 PM   #90
An old Tradesmen
You keep only talking about the compressor. Moisture lays in other areas, besides the compressor.
High rise Plumbing question roach_779 Off Topic 8 01-17-2011 08:36 PM
DIY Advice Seeker - late 1970 seventies knockdown texture onegative Drywall & Plaster 1 04-22-2010 08:40 AM
Rheem Criterion 2: high fan heat only dyincolor HVAC 2 03-27-2010 09:17 PM
Hunter Ceiling Fan: Won't do high speed ConstantChange Electrical 4 09-28-2009 03:00 PM
Electrical Advice Caution!!! Mike Swearingen Electrical 12 03-05-2008 11:51 AM
