Stumped! Heil Furnace. - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-23-2012, 09:48 PM   #16
Here it is.
Ashpadgett55 is offline   Reply With Quote
Old 10-23-2012, 09:52 PM   #17
Also I am getting 28 volts with the unit on and just sitting. Is that what it should be? And by on I just mean on. Not going through the sequences just sitting at idle.
Old 10-23-2012, 10:03 PM   #18
Rewards Points: 582
did you try putting old ignitor back on....that is exactly the ignitor that did not work for me..... that my or maynot be your problem...
Old 10-23-2012, 10:07 PM   #19
The one I took a pic of is the old one, but it is the exact same one I just put on. Should I get 28 volts at the gas valve where the 3 wires go in from the igniter?
Old 10-23-2012, 10:14 PM   #20
Rewards Points: 582
yes .valve controls ignition of burnners after pilot flame is proved..there is a click in the valve opening it up...ben sr
Old 10-23-2012, 10:17 PM   #21
Sounds like bad gas valve then. I don't get that last click to fire burners. The weird thing is that the gas valve is only a year old.
The Following User Says Thank You to Ashpadgett55 For This Useful Post:
ben's plumbing (10-23-2012)
Old 10-23-2012, 10:21 PM   #22
And for the record I appreciate everyone's input on here. I own a roofing company so I will be helping people with roofing questions to return the favor. Great site to be a part of.
Old 10-23-2012, 10:29 PM   #23
Just tested the valve with the pilot lit and only got 15 volts. Stumped again
Old 10-23-2012, 10:38 PM   #24
Rewards Points: 530
Hopefully this works. Here's a pic
Where do you check that valve for proper voltage. It is very similiar to one on a unit I am having trouble with.
Old 10-23-2012, 10:45 PM   #25
Rewards Points: 582
see if this will help you
Old 10-23-2012, 10:55 PM   #26
What voltage should I have while the pilot is lit?
Old 10-23-2012, 10:58 PM   #27
Rewards Points: 582
you could also try pulling the plug on control board p1 and plug it back in to see if maybe a loose connection...not what you want to hear...but it seems like another defective valve... follow that chart ......
Old 10-23-2012, 11:05 PM   #28
Rewards Points: 582
its a 24 ignitor ....24 volts...
Old 10-23-2012, 11:23 PM   #29
That's what I figured. I'm not getting that when the pilot is lit. It moves between 12 and 15. Hmmmm
Old 10-23-2012, 11:30 PM   #30
Rewards Points: 582
dosen't seem right if the pilot is lit it has to have 24 volts to fire ignitor...
Tags
furnace , gas valve , heil , main burner
heil furnace ? grizzlyadams73 HVAC 3 04-10-2011 08:14 PM
Heil Gas Furnace Not Lighting kasi42 HVAC 21 10-09-2010 05:40 PM
Heil NG Furnace - Combustion blower never turns off PHRoberts HVAC 4 06-11-2010 05:37 AM
Heil furnace issue sbriggs_1 HVAC 19 12-05-2008 06:07 PM
heil furnace bbr67 HVAC 5 02-24-2007 01:22 AM
