Stubborn Furnace Or Prog. Thermostat? - HVAC - DIY Chatroom Home Improvement Forum
Old 01-06-2010, 09:11 PM   #1
Stubborn Furnace or Prog. Thermostat?
I have a forced hot air furnace, Carrier gas model. I also have a programmable thermostat programmed to come on at 4:30 up to 66 degrees. When I get home from work the blower is not on and the temp on the thermostat reads around 60, where it is programmed to be during the day. If I cut the power either at the E switch or the breaker and then turn it back on the blower starts up and the house heats up. Any obvious problems??
almostgreen is offline   Reply With Quote
Old 01-06-2010, 09:49 PM   #2
An old Tradesmen
Rewards Points: 6,098
The furnace is locking out.
Look for an error code.
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 08:48 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 04:57 PM
