Originally Posted by berr3555
The past few days I've noticed that the outside unit has developed a humming/irregular sound, it sounds to me like a bearing is going bad. While running I listen around the unit and it seems like the noise comes from the upper part of the unit. When I put my ear close to the bottom the compressor seems to sound normal. But with all the different noises going at the same time is hard to isolate exactly where is coming from. I replaced the original fan like 3 years ago with a GE fan that I got from Locke. That fan failed within the 1 year warranty and I got it replaced. The current fan has around 2 years in the a/c. I was thinking of disconnecting the compressor wire out of the capacitor so the fan will run by itself to verify if is actually the fan what is going bad. I want to make sure that I do not harm any other component of the unit by taking this troubleshooting approach. Any help is greatly appreciated, thanks.
Sometimes a good fan motor DIY diagnosis is to watch the motor coast down. After a good reasonable coast down time I like to see the fan blade rock back in the opposite direction just a bit. With a bearing that's failing rock backs are uncommon.
That many motor failures aren't very normal so unless you didn't remove the drain plug a professional may need to determine why all the failures.
